Question-I have new (ish) UCA's, should I replace mine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Jul 26, 2019.
  1. Jul 26, 2019 at 1:20 PM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    They have 50k on them and I will have the upper ball joint loose next week when I do my lift? Just wondering since I am there and I have basically new ones if I should bother. What say you?
    Thanks in advance
    Pat.
  2. Jul 26, 2019 at 6:51 PM
    Taco'09
    Taco'09 Well-Known Member
    OP. the lift experts will show up in a bit but are your UCAs stock? And how much lift are you planning? If it is a lot you may have a tough time meeting alignment goals. A lot of lift will generally necessitate aftermarket arms with built in positive caster adjustment such as those from JBA or additional caster adjustment such as the arms from SPC.
  3. Jul 27, 2019 at 11:28 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    2" lift with 3rd gen strut assemblies and spacer. Shouldn't need "larger: UCA's, just wondering if since I am there and I have new ones that came from the 3rd gen if I should put them on. That's all.
