Question...Improving Traction in Snow for 1998 PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by cobb.bd, Nov 25, 2011.
  1. Nov 25, 2011 at 11:01 AM
    cobb.bd
    cobb.bd [OP] Well-Known Member
    Hello Everyone,
    My wife and I are having to move due to employment. We currently live in an area where it only snows on occasion, however it will snow regularly where we are moving to.
    Currently I have a 1998 PreRunner with the full OME kit and 32" BFG All Terrains. My truck is not a TRD model, thus it does not come with a limited slip differential.
    Does anyone have any experience and/or recommendations for driving in snow and adding additional traction with a PreRunner. I know how to drive in snow, I would just like some addition input on a way to gain additional traction.
    Also, I am considering installing a Detroit Truetrac Limited Slip...anyone have any experience on this.
    Thanks for the assisstance.
  2. Nov 25, 2011 at 11:05 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    No experience with the truetrac.
    But weight is the key to get more traction for rear wheel driving. I barely ever use my 4wd in the winter, only time i use it is when im stuck in the snow or driving through +6" of snow. Sandbags
  3. Nov 25, 2011 at 11:52 AM
    cobb.bd
    Yes, forgot to mention the sandbags.
  4. Nov 26, 2011 at 3:34 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I would suggest snow tires. Mud tires suck in snow, snow tires are a night and day difference.
  5. Nov 26, 2011 at 7:59 AM
    ratso
    ratso Well-Known Member
    northern ca2
    sr5
    Camburg coilovers,ARB, warn 9000,avic d3,KN cold air,poweraid, optima yellow top,line x
    Im not sure a locker or limited slip will help.It will definitely be fun to drive,until you get sideways and stuck.
  6. Nov 26, 2011 at 8:08 AM
    spezzy
    spezzy Well-Known Member
    Thayne
    Eau Claire, WI/ Fort Irwin, Ca
    09 Red Sport Taco
    Yep, thats how we do it in Wisconsin! Worse comes to worst .... :turtleride: or a dog team.... just an idea.
  7. Nov 26, 2011 at 11:16 PM
    cobb.bd
    So the limited slip would not help with traction or improve driving in snow?
  8. Nov 27, 2011 at 8:20 AM
    ratso
    northern ca2
    sr5
    With having power to both rear tires the traction is better.T
    he rear will then push the front.This will cause you get sideways.If you do a 180 on the road it will be hard to just back up and straighten out with snow and ice.
  9. Nov 27, 2011 at 8:57 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    studded tires?
  10. Nov 27, 2011 at 9:37 AM
    cobb.bd
    No studded tires, just the stock BFG All Terrains.
  11. Nov 27, 2011 at 9:41 AM
    cobb.bd
    So...it looks like I should save myself the $500.00 and go just with the sandbags and possibly a set of chains.
  12. Nov 27, 2011 at 10:14 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    yes. A locked rear end or limited slip can worsen traction in the snow for rear wheel drive vehicles. A good set of tires (tall, skinny and snowflake rated), some weight over or in front of the axle in the bed (don't put weight behind the axle, you want to weigh down the rear without unweighting the front) and going light on the skinny pedal is the best you can do in the snow. Studded snows are great and chains are awesome if you are constantly in deeper snow or unmaintained roads.
  13. Nov 27, 2011 at 10:19 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Sand bags!!! Chains if required by the state for any mountain passes.
  14. Nov 27, 2011 at 11:14 AM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    I like rud tire chains with twisted links. Usually carry a full spare and 100-200lbs worth of tools/sand and you'll be set. My jeep with a spool in the back handles like shit in on snowy roads but great in the deep stuff. I would just weight it down and get a really goo
  15. Nov 27, 2011 at 11:27 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Weight it down and get a really goo......um what? :confused:
  16. Nov 27, 2011 at 12:02 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    I would get goodyear duratracs and stud them. I've heard they are awesome in the snow and they come predrilled for studs. An LSD or locker will help u get our of snow when ur stuck but can make handling unpredictable at speed.
  17. Nov 27, 2011 at 2:36 PM
    cobb.bd
    I think I will stick with the BFG All Terrains, not looking to spend much more on tires since I just bought the BFG's. I will get some sandbags and place accordingly over the axle. Also, I will have to invest in a set of chains.
  18. Nov 27, 2011 at 4:23 PM
    BigBlueTaco
    BigBlueTaco Member
    Tacoma D-Cab 4x4
    I run Nordman SUV (studded) and rarely use my 4WD in Alaska. I have 5 40 lb sandbags over the rear axles too.
  19. Nov 27, 2011 at 4:32 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    I've run nothing but BFG ATs on all my trucks since moving out to Colorado and they've been nothing short of very solid on snow/wintry roads going up and down mountain passes for the past 20 years
  20. Nov 28, 2011 at 12:38 AM
    87xjmike
    Folsom
    98 5lug 2rz
    Sorry damn Ihone... Meant to finish it off with really good chains. Or if your in a pinch you can always cut down semi truck chains which are a dime a dozen on c-list. And yes Bfg at's fit the bill nicely in snow.
