Question: Lifting 5 Lug
Discussion in '5 Lug' started by CorysTaco, Mar 25, 2018.
  1. Mar 25, 2018 at 1:49 AM
    CorysTaco
    CorysTaco [OP] Active Member
    Cory
    2004 White Tacoma
    Wheels, Tint, Subs/Amp
    Hello, I’ve got a question, can I stack the 1.5” Front Poly Spacer with a 3” Spindle lift to result in more lift? Just want to make sure won’t cause any ware-and-tear on my truck. Also, if I were to stack them two together then do the Leaf spring add on that comes with the 3” spindle lift kit, would it make my truck squat since front is 4.5inches total?
    Thanks!
  2. Mar 25, 2018 at 11:09 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I have a spacer and spindles up front and a leaf spring and shakles in the rear and the rear sits about 1”, but i do have camper and stuff in the bed. With just a leaf in the rear yes it will squat. I would recommend doing just shakles if you wanna keep your ride nice, leaf and shakles if you want the lift. The leaf will stiffen your ride though
  3. Mar 25, 2018 at 11:19 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But the 1.5” spacer doesn’t really give 1.5” more like .5-1” if that. If I could go back in time I wouldn’t have done the spacer not worth the headache for the little lift. When I install my doetsch lift im not gunna even bother to put it back in.
  4. Mar 25, 2018 at 5:42 PM
    CorysTaco
    Cory
    2004 White Tacoma
    It says that it will level the front and back, did it for you? And how big of a lift you getting?
  5. Mar 25, 2018 at 5:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean when I installed the spacer i all installed an aal, the back sat a little higher even after everything settled down. In sure with no aal it will level it. And im doing Anothony 3” lift on top me 3” spindle lift so 6” in total
