Question- New lift kit installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LawrenceB, May 10, 2018.
  1. May 10, 2018 at 10:58 AM
    LawrenceB
    LawrenceB [OP] Member
    Rochester—NY
    2017 SAND OR
    I have a 2017 OR double cab and just installed 5100’s in the front with OME 887. The mechanic set the perch in the middle setting. I told him initially to set at the bottom since I was hearing problems when it wasn’t.
    Should I be concerned at this point? The alignment seems okay right now. TIA
  2. May 10, 2018 at 11:08 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You are good- I set mine to #3 and all is fine with alignment and no bearing noises. Only some people get the bearing issue and require the ECGS Bushing upgrade.
  3. May 10, 2018 at 11:09 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    There's no "problem" setting them in the middle, I'd be more irritated that you asked your mechanic to set it up one way, and he set it up a different way.
  4. May 10, 2018 at 11:19 AM
    LawrenceB
    Rochester—NY
    2017 SAND OR
    Ok thanks guys! I was going back and forth on whether I should get UCA’s to off set the issue.
  5. May 10, 2018 at 11:24 AM
    LawrenceB
    Rochester—NY
    2017 SAND OR
    How would I know if was a bearing issue?
    Do you have 887’s and speak from experience? Do you get excessive rubbing on your tires?
  6. May 10, 2018 at 11:28 AM
    OnHartung'sRoad
    You didnt mention the tire issue. Sounds like a problem if you have that too.
  7. May 10, 2018 at 11:37 AM
    LawrenceB
    Rochester—NY
    2017 SAND OR
    The rubbing is only when I take sharp turns. I have 285/75/16.
  8. May 10, 2018 at 1:44 PM
    OnHartung'sRoad
    Ah, ok - well there are certain conditions where the bearing issue will come up- search for ECGS bushing here to see that. It happens after a lift, but not to everyone. I have 265/75/16’s without rubbing, 5100’s on and stock coils. My total lift up front with my 3rd click shock setting was about 1.5” - are your shocks and 887’s much higher? I would think that lowering the shock settings may exasperate your tire rubbing, especially when off-roading and going downhill on a sharp corner. My 1st Gen had 285’s and was bad for that.
  9. May 10, 2018 at 1:58 PM
    LawrenceB
    Rochester—NY
    2017 SAND OR
    No I think it’s about that height. I just looked and I’m not actually rubbing on the frame but against the upper control arm when I make tight turn.
  10. May 10, 2018 at 2:01 PM
    OnHartung'sRoad
    Mine hit the cab mount, but it was a totally different model. It must look good with those tires, probably some other options here to keep them.
