Question on 18 inch rims
Discussion in 'Wheels & Tires' started by deadbolt, Aug 25, 2008.
  1. Aug 25, 2008 at 7:31 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
  2. Aug 25, 2008 at 7:35 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I'm running 265/50/20 without a lift and without rubbing.
  3. Aug 25, 2008 at 9:32 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Rim size won't make a difference as long as you stay below a 33" tall tire. With a lift you will be able to fit the 33s. There is a post on how tall of a tire you can fit on a factory truck.
  4. Aug 26, 2008 at 6:35 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    285/60R18 should fit fine w/out a lift
  5. Aug 26, 2008 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nope. It will rub. A 32" tall tire that is 10.5" wide will fit without rubbing (265/75/16)....
  6. Aug 28, 2008 at 9:15 AM
    deadbolt
    Socal
    so what tire size do u guys recommend for the 18s that will not rub
  7. Aug 31, 2008 at 9:37 PM
    deadbolt
    Socal
    so tempted to buy them now since they are 15 percent off at 4wheelparts
  8. Aug 31, 2008 at 9:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    a 265/60/18 is the closest size to stock. I just calculated what you would need for height and width on an 18" wheel. Not sure if this size exists or not.
  9. Aug 31, 2008 at 9:48 PM
    deadbolt
    Socal
    ill checkkk on some tire sitess
