Question on 2004 Tacoma shocks struts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wb mest, Jun 19, 2023.
  1. Jun 19, 2023 at 10:44 AM
    Wb mest
    Wb mest [OP] Active Member
    2004 Tacoma 5spd TRD
    I need to replace shocks and struts. I have a 4x4, manual, TRD. Any recommendations on what brand, model and I was quoted $1050. Does that seem high?
    Thanks!
  2. Jun 19, 2023 at 10:52 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    A very Good thread A few threads down.
    Shocks and struts a whole set !
  3. Jun 19, 2023 at 10:56 AM
    Wb mest
    I am newbie here. What do you mean by "A very Good thread A few threads down". Thanks!
  4. Jun 19, 2023 at 10:58 AM
    Bivouac
    look again .
    On the first generation Page go down to you see the thread Shocks and Struts a Whole set.
  5. Jun 19, 2023 at 11:30 AM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
  6. Jun 19, 2023 at 11:32 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    There are plenty of step by step tutorials here on TW as well as how to, YouTube videos. Save yourself the $1000 bucks and DIY it.
  7. Jun 19, 2023 at 8:54 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    It really depends on what they're selling you, many shops will use an aftermarket solution like Monroe Quick Struts which I guess aren't very good and have a reputation for leaking in a very short time. If a shop is giving you OEM shocks and springs for $1050 I'd jump on it myself! :p
    It also depends if you want to go stock or get some lift, Bilstien 4600's are the most popular choice for stock height shocks.
    Being in the market myself, see the thread mentioned by Bivouac, right now I'm vetting a company selling assembled coilovers with Bilstein shocks and Moog coils, everyone seems reluctant with this company but their price can't be beat for that package, around $725 with coupon and free shipping. Expect to fork out at least $800-$1500 for good shocks and coils, which is why $1050 makes me a bit suspicious.
  8. Jun 19, 2023 at 10:07 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Post some pics of your truck. Does it have a stock suspension. If you're looking to keep it stock go with Bilstein 4600 shocks. You could even google Bilstein 4600 shocks for 2004 Tacoma 4x4 and find several good links and videos. Skies the limit or maybe your budget.
  9. Jun 23, 2023 at 9:36 AM
    Wb mest
    I ended getting a bid for Bilstein 4600s for my 04 tacoma for $1500. Does anyone have a recommendation for a comparable shock like a Rancho that may be just a bit less expensive? Thanks!
  10. Jun 23, 2023 at 2:23 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Are you saying that's a quote to buy and install 4 shocks. No way dude, that's highway robbery. you can get 4 of these shocks from Amazon, just as an example
    https://www.amazon.com/Bilstein-Abs...cint=&hvlocphy=&hvtargid=pla-4584070153140187
    so charging you over 1k for installation is just nuts. Ask for some help here on TW in your area. members are always willing to help out a Newbie if you have limited mechanical skills. that quote is waaayyyy to high.
    Area51Runner likes this.
  11. Jun 23, 2023 at 2:51 PM
    Wb mest
    I will ask if anyone knows of a garage in Denver that works on older Tacomas. I would love to find one. Yes, I am not mechanically inclined and live in condos, etc. That is $250 labor per wheel. Thank you for your input.
  12. Jun 23, 2023 at 3:21 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    If that's $250 labor per wheel, then it's $1000 for parts that should only run about $400 (give or take). Don't pay that bizarre markup
  13. Jun 23, 2023 at 3:23 PM
    Red_03Taco
    Jerad
    Even $250 per wheel is highway robbery for labor too. A good mechanic could do both shocks in an hour. I could see 2 hours labor being fair if they had to assemble the coilovers themselves. But $250 per hour of labor would be way too high.
  14. Jun 23, 2023 at 3:26 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Check the many threads in the Colorado subforum, might be able to connect with someone local who can help.
    https://www.tacomaworld.com/forums/colorado.172/
    Bivouac likes this.
  15. Jun 23, 2023 at 3:54 PM
    Wb mest
    Thank for that Colorado subforum tip.
  16. Jun 24, 2023 at 4:15 AM
    Bivouac
    I have seen some crazy high labor quotes lately !
  17. Jul 5, 2023 at 1:25 PM
    Wb mest
    I am about to have a garage put Bilstein 4600s on my 04 tacoma, 4x4, trd, manual, 6 cyl 3.4 and have been reading where the original bilsteins were not actually bilstein 4600s. My question is if 4600s will fit my truck and are a good shock/strut, right? I have no lift just a slightly bigger tire LT265/75/R16. I am also not replacing the front coil springs right now for money reasons. This work is $1500. I got 2 other bids - one $1600 for Bilstein 4660s and $1500 for Monroes. Any input helps - thanks in advance.
  18. Jul 5, 2023 at 1:29 PM
    Area51Runner
    I'm sorry, I'm confused. 4600s vs 4660s. Have a link to these 4660s that the shop is quoting you $100 more for?
  19. Jul 5, 2023 at 1:30 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You're going to be fine with 4600s. The difference was a small delta in shock body diameter. You'd never be able to tell the difference behind the wheel. You're going to be happy with the 4600s over the Monroe garbage.
    Area51Runner and Wb mest[OP] like this.
  20. Jul 5, 2023 at 1:32 PM
    Wb mest
    I meant 4600s. 4660 was a typo.
