question on a trd.
Discussion in '1st Gen. Tacomas (1995-2004)' started by scheide, Aug 24, 2013.
  1. Aug 24, 2013 at 3:29 PM
    scheide
    scheide [OP] Well-Known Member
    nebraska
    84 toyota
    4.88 gears, marlin crawler, 4" lift,lockers front and rear,33x10.5 swampers, header, u-bolt flip kit,relocated shocks in rear,walker muffler, pinion e-brake conversion,9000 ramsey winch.
    So today I installed an AAL in the rear of my 99 trd. Had both tires off and jack stands installed under the axle. My question is when rotating one hub, the other one turned also. Doesn't this only do that if there is a locker? Or is it limited slip also? I guess I really not sure how it works with the diff. lock switch. Can someone explain how this works. On my 84 I have a locker in the rear, and it acts the same way. Both tires off, spin one side and the other turns.
  2. Aug 24, 2013 at 4:23 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Since you have both tires off, that means there is no friction/resistance to stop a wheel from moving. I think an open diff will do that with no load on both tires.
    I think that is right....but someone will correct me if not....lol.
  3. Aug 25, 2013 at 6:54 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Yeah an open diff will allow the other wheel to be spun in the opposite direction when they're in the air
  4. Aug 25, 2013 at 7:40 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    normal for both open/ lock diff until u switch on locker then both turn same direction
