Question on aftermarket UCAs and a shop in PA
Discussion in 'Suspension' started by PA Tacoma, May 19, 2010.
  1. May 19, 2010 at 7:56 AM
    PA Tacoma
    PA Tacoma [OP] Member
    Nyles
    East Earl, PA - Tanauan, Philippines - Baghdad, Ir
    05 Access Cab TRD Off Road
    Custom wheels, Haven't had time for anything else
    I've already bought a 3" lift kit (Toytec OME3-05-AL) in 2007, but due to work outside the U.S., I've been unable to install. I've been doing alot of reading on the need for UCAs to correct the issues with alignment after the lift is installed. I was looking at Toytec's website today and saw they had a set of Light Racing UCA's that are considerly less expensive then the other brands. Is this a quality brand? What would you recommend? I don't off-road much at all, infact I only drive the Tacoma very 6 months for a 2 week period of time, so it's more for looks than really driving off-road. Also I'm looking for shop in Lancaster County, PA who can install the lift and UCAs for me. Thank you for your help.
  2. May 19, 2010 at 8:04 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    the LR UCA's reuse the stock ball joint instead of a uni ball like camburg, and TC.
    they are more intended to correct alignment and not so much increase off road performance.
    it sounds like they are the right choice for you. PM toytec and they will offer you a TW discount
  3. Aug 7, 2010 at 1:12 AM
    scottj
    scottj Well-Known Member
    York, PA
    12 DCSB TRD sport OME
    offroadcentral.biz - Shop is on columbia avenue, lancaster, pa
  4. Aug 9, 2010 at 8:06 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I have LR UCAs on my 98. They are for adjusting caster on lifted vehicles.
    A uni-ball UCA will help more with articulation for off road.
    If you truck wanders and you want to fix this go with the LR UCAs.
