Question on behind the grille brackets
Discussion in 'Bay Area Metal Fabrication' started by beyer075, Nov 23, 2014.
  1. Nov 23, 2014 at 8:40 PM
    beyer075
    beyer075 [OP] Rock Licker
    Northern Nevada
    2016 White TRDOR
    Hello,
    Looking to put an led bar behind the grille but I'm a bit confused with the two options on the website since the pictures are the same for both. What are the differences between the mounts and the brackets?
    Thanks!
  2. Nov 23, 2014 at 8:50 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
  3. Nov 23, 2014 at 9:06 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Its all in the Description the LED light bar only will not work unless you have the main bracket. There is no difference between the brackets there is just an option for you to just buy the LED mounts if you already have the main bracket.
  4. Nov 24, 2014 at 4:47 AM
    beyer075
    Northern Nevada
    2016 White TRDOR
    Just wanted to make sure.
    Thanks!
