Question on camber/caster
Discussion in 'Suspension' started by IrishTaco, Dec 9, 2010.
  1. Dec 9, 2010 at 3:48 PM
    IrishTaco
    IrishTaco [OP] Active Member
    Patrick
    Fort Lewis, Wa
    08 4x4 TRD Sport 6spd
    Window Tint, K&N Air filter...ideas?
    As a newbie to having a 3" (5100's) lift and still needing an alignment i was reading around and someone said to get it with your caster as high as possible and your camber as low as they can get it. Is this right? will factory specs not work on a taco with a lift? will most shops do this?
  2. Dec 9, 2010 at 4:00 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The alignment shop should be able to get the Camber, and Toe close to 0. The Caster will be low, but they should still try to get it as high as they can with out messing up the other two.
  3. Dec 9, 2010 at 6:52 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    With 3" of lift you will likely need new UCA's to get the caster right.
  4. Dec 9, 2010 at 6:54 PM
    IrishTaco
    Patrick
    Fort Lewis, Wa
    well its really 2.5 with the aal and 5100's. heard you dont need uca's for that.
  5. Dec 9, 2010 at 6:58 PM
    KPT
    09 Prerunner
    With 2.5" some need new uca's, some don't.
  6. Dec 9, 2010 at 7:00 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    per chris4x4
    You should have 0* Toe and Camber, and about 2.4* Caster.
  7. Dec 9, 2010 at 7:25 PM
    ekard
    ekard Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    That's been bugging me. Why 0 camber on our trucks?
    I thought some negative camber up front was good for cornering (ex: I've always maxxed out my front negative camber on my Subaru).
  8. Dec 10, 2010 at 5:39 AM
    KPT
    09 Prerunner
    It's a trade off....a more aggressive camber setting will help you corner better but wears out the inner edge of the tire quickly.
    I had my camber maxed out my my subaru as well and my tires lasted 18,000 miles before the inner edge was down to the cord. (They were falkens though, terrible tire IMO)
  9. Dec 10, 2010 at 8:40 AM
    ekard
    San Jose, CA
    2011 DC SB 4X4 OR
    That's all? I was hoping there was a more complicated explanation for our trucks... :bored:
    For what it's worth, I've never had tires wear due to camber. Toe, yes, but never camber.
