Question on clock spring?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdg, Jan 17, 2024.
  1. Jan 17, 2024 at 9:25 AM
    jdg
    jdg [OP] Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    I have a 2015 SR5, my steering wheel lock when you turn the key off has stopped locking, when the key is turned off, and the key is out you can still turn the wheel. My horn doesn’t honk unless you move the wheel a little to one side or the other. Is it a bad clock spring that is my problem? Can I change out the clock spring and that will fix it or is there more to be done? Thanks!!!
  2. Jan 17, 2024 at 9:34 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The horn problem sounds like a bad clockspring but the steering wheel lock is a separate issue, it is in the part that holds the lock cylinder.
    jdg[OP] likes this.
  3. Jan 17, 2024 at 9:52 AM
    jdg
    David
    Texas Panhandle
    All the time!!!
    So a new ignition key assembly is what I need to lock the column again, and a clock spring assembly also. I’m just trying to make sure I have what I need before I take it apart. Thanks!
  4. Jan 17, 2024 at 9:54 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think it's the part that the lock cylinder goes in not the lock cylinder itself but I could be wrong.
    Jimmyh and jdg[QUOTED][OP] like this.
