Question on driving a manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ortlie09, Jan 10, 2012.
  1. Jan 10, 2012 at 1:24 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Using the clutch start cancel button to start the truck in neutral will do NO harm to anything. I frequently use the button when the truck is in neutral to warm it up. The clutch start cancel is used to start the truck in gear when off road. If you are in low range on a hill and cant roll backwards, push the button when you are in gear and hit the starter and go. This is hard on the starter but it is has gear reduction to help out.
  2. Jan 10, 2012 at 1:27 PM
    Sunner
    Sunner Well-Known Member
    http://www.tacomaworld.com/forum/of...ybody-ever-use-their-clutch-start-cancel.html
    I guess you guys are not the only ones doing it. SO musnt be that bad. I didn't read it in my manual but Im sure its there, I actually heard it on the little CD that comes with the truck that explains some of the features(Yes I actually listened to it)
  3. Jan 10, 2012 at 1:28 PM
    scocar
    scocar hypotenoper
    I don't see how it is bad, at least mechanically. It is just a bypass for the cluth pedal switch. I used to use this on my 93 when I was working on it and just needed to start it but still had the hood up, and also didn't want to get my grubby ass coveralls on the seat. The real function of it is for tricky hillstarts when you are at a dead stop and don't have three feet, usually in 4-low.
    Operator-error wise, this could be a bad habit from a safety and insurance premium perspective.
    edit: OK, it looks like at least three of us have explained to so far...
  4. Jan 10, 2012 at 1:30 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    My procedure on ALL my manual transmission vehicles...
    Take truck out of gear, push in clutch, start engine, release clutch, let warm, remove parking brake, go...
    From everything from motorcycles to 1 tons...
    This reduces the drag from clutch and cold gear oil to a minimum.
    Howard
  5. Jan 10, 2012 at 1:33 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Explain how?
  6. Jan 10, 2012 at 1:34 PM
    Sunner
    The best safety measure of your truck not rolling away IMO is to leave it in Gear, I always do. I don't trust the praking brake too much
  7. Jan 10, 2012 at 1:39 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    You don't trust the PARKing brake to keep your vehicle PARKed?
  8. Jan 10, 2012 at 1:43 PM
    Sunner
    Nope, I understand that is what it is meant for but I've seen them fail. Why not just make sure your not going to go anywhere and take that extra step of putting it in gear as a precaution?
  9. Jan 10, 2012 at 1:44 PM
    hetkind
    Howard
    Johnson City
    Never have and never will...in gear AND parking brake on. Unless it is going to sit for a while, the parking brake off, out of gear, wheels chocked.
    Having a parking brake lock up is a bad day...
    So use the brake often, and it won't sieze.
    Got a few stories about siezed parking brakes over the years, but it was the siezed parking brake in my FJ60 that made me get my first home shop press.
    Howard
  10. Jan 10, 2012 at 1:52 PM
    scocar
    scocar hypotenoper
    Nope. Standard operating procedure. Grew up in a hilly area. If I am facing downhill, I will actually put it in reverse when parked.
  11. Jan 10, 2012 at 1:53 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  12. Jan 10, 2012 at 2:07 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    X2. Ive seen parking brakes fail several times.
  13. Jan 10, 2012 at 3:04 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    How is putting it in reverse any different than putting it in first (other than the difference in gear ratio)? Doesn't the engine have just as much difficulty spinning in one direction as the other?
  14. Jan 10, 2012 at 3:14 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i was always told that first gear is the "strongest" gear..Always leave mine in first, unless on a hill. Then its first and parking brake.
  15. Jan 10, 2012 at 3:17 PM
    #35
    OZ-T
    Peter North
    British Columbia
    Leave it on a hill , in first , and leave the parking brake off , see what happens
  16. Jan 10, 2012 at 3:33 PM
    #36
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Bingo leave it in 1st gear push that button turn that key you might get a nice big hole for a new door.
    I use it in the morning sometimes when I'm not going to leave (warm it up, clean my shoes or something). I don't have to get in, I reach over make sure the shifter is out of gear (moves left to right a few times) hit the button turn the key.
    I thought it was for starting with a broken clutch or something. Then you have to know how to up & down shift without a clutch. Bring the rpm's up up shifting & let them drop when down shifting.
  17. Jan 10, 2012 at 3:40 PM
    #37
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I had no idea that the clutch cancel button was for a lurching start if you don't want to roll back. Interesting. I guess it makes sense.
    I thought it just for if you were feeling lazy...
  18. Jan 10, 2012 at 3:43 PM
    #38
    Mr.Ed
    Wilbur's Barn
    someone can push the clutch in and put the right foot on the break to start or the parking break. I don't under stand why it would be used that way. I was thinking it was to push start (pop start) or something like that.
  19. Jan 10, 2012 at 3:47 PM
    #39
    scocar
    scocar hypotenoper
    :popcorn:
  20. Jan 10, 2012 at 3:47 PM
    #40
    Mr.Ed
    Wilbur's Barn
    That's nonsense you have two breaks. hill start Why would anyone use it? Someone tell me why they would not use the breaks or hand break.
