Question on FF on our 2nd gens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp5385, Dec 5, 2021.
  1. Dec 5, 2021 at 8:27 PM
    Jp5385
    Jp5385 [OP] Well-Known Member
    2014 TRD Sport V6 4x4
    Hey guys I was going to Fluid Film the rocker panels and the drain holes of my door this weekend. I have a 2014 Tacoma.
    My question is the rocker panel has rubber plugs I have to pull out to shoot FF inside the rocker panels. I heard FF can swell up some rubbers. Does anyone know if those rocker panel plugs will be affected by the FF? Or the rubber on the door drain holes?
  2. Dec 6, 2021 at 9:46 AM
    Jp5385
    Anybody know this?
  3. Dec 6, 2021 at 10:30 AM
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    Mine weren't affected.
    Jp5385[OP] likes this.
  4. Dec 6, 2021 at 11:18 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have been spraying my frame every yr since 2014 and never noticed any damage or swelling on anything rubber.
  5. Dec 6, 2021 at 1:01 PM
    Jp5385
    yeah I’m not spraying the frame just the rocker panels but they have a rubber plug, wasn’t sure if the FF affected those plugs. Thanks for the replies guys.
  6. Dec 6, 2021 at 1:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe it affects foam rubber and natural rubbers. For example the door seals, I’d try not to get it on those. Other wise, I’ve not had any issues using it on my mowers. Which is the only time I’ve ever used FluidFilm.
    burrito782 likes this.
  7. Dec 6, 2021 at 2:16 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
  8. Dec 6, 2021 at 2:20 PM
    TnShooter
    Deogee
    STOCK
    I missed that post.
    I recall reading about the foam when I was researching if it was ok to use on plastic. I use FF on my battery powered hedge trimmer. I use it on the blades to keep them from rusting. But some inevitably gets slung off on to the plastic.
    So far, everything has been fine.
  9. Dec 6, 2021 at 2:34 PM
    burrito782
    08 TRD Off Road
    What you say and the thread link I provided earlier jives with the following FF response to whether it adversely affects plastic and rubber (taken from their website): FLUID FILM has no adverse effects on plastics. Caution should be used around non oil-resistant rubber goods. May cause swelling.
    wi_taco and TnShooter[QUOTED] like this.
