question on front and rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD 13, Aug 6, 2014.
  1. Aug 6, 2014 at 1:39 PM
    TRD 13
    TRD 13 [OP] Active Member
    Spencer, WV
    2013 TRD double cab short box 6 speed
    6" rough country lift, 35" mud terrains
    OK, so this is only my second post on the forum. Im brand new to Tacomas, so don't shoot me. I just had my 2013 double cab TRD lifted 6" with a Rough Country kit and 35's put under it. I called a local shop this morning to schedule a time to have my front and rear diff gears changed to 4:56's. The shop tech told me he will need to know what size diffs are in the truck before he can order parts. Toyota didn't use different size diffs in these did they?
  2. Aug 6, 2014 at 1:40 PM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    TRD Off Road has 8", Sport has 8.4"
  3. Aug 6, 2014 at 3:21 PM
    TRD 13
    Spencer, WV
    Thanks for the clarification! I do have the TRD Sport. Looks like that makes all the difference. When I bought mine the dealer told me the only way I could get the 6 speed std. was in the Sport. That's the whole reason I went that direction.
    Thanks again.
  4. Aug 6, 2014 at 3:35 PM
    Large
    Large Red
    FWIW you can get a 6 sp O/R version, the dealer is full of shit.
  5. Aug 6, 2014 at 5:25 PM
    TRD 13
    Spencer, WV
    Well that sucks the big one! I looked at two different dealers. All I could find in 6 speed was Sport. I hate the scoop, but dealt with it in order to get the 6 speed. Both dealers told me that I could not get 6 speed O/R in the U.S :confused:
  6. Aug 6, 2014 at 7:09 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Wow, sounds like the salesmen really knew their stuff. :rolleyes: While they seem to be getting more uncommon, they do make the 6spd in o/r models. As far as i know, the only models you CAN'T get a 6spd in are the longbeds. Love my manual. For the record, if you're spending the money like it looks like you are, then you can make a Sport as strong, if not stronger, than the o/r. 8.4 is stronger rearend, just install an ARB when you're puttin those gears in!
  7. Aug 6, 2014 at 7:10 PM
    smd3
    smd3 Well-Known Member
    Throw a locker in when you get the gears and you've essentially got an OR. you've already replaced everything else that comes on the OR over the sport. I think you're only missing ATRAC, which isn't that big of a deal.
  8. Aug 6, 2014 at 7:12 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Have you considered getting lockers put under your truck? Sure would be a shame to get all that gearing done just to get your "Monster Truck" stuck on terrain that a factory OR could handle better.
  9. Aug 6, 2014 at 8:45 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I would also strongly consider buying already assembled thirds (the part that holds the gears) and not trusting the local shade tree mechanic to swap gears if he can't even identify what he's looking at. ECGS has great prices and warranty their work. You can then have your local hillbilly with a crescent wrench install the thirds, or do it yourself. It's pretty easy, lots of youtube how to's out there.
    You want this one- http://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html
    and this one- http://eastcoastgearsupply.com/i-157223-tacoma-fj-8-reverse-ifs-clamshell.html
  10. Aug 7, 2014 at 3:44 AM
    TRD 13
    Spencer, WV
    Thanks. Im no stranger to turning wrenches, just new to Tacomas. Ive built both demolition derby and circle track cars for years. The third member idea is a good one! I will look into it for sure. Thank you for your assistance!
  11. Aug 7, 2014 at 3:46 AM
    TRD 13
    Spencer, WV
    I had thought about it, it only makes sense to do it. Thanks.
  12. Aug 7, 2014 at 3:51 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Be happy you bought the sport vs or im on diff #3 on my way to 4 soon
  13. Aug 7, 2014 at 3:53 AM
    Large
    Large Red
    You have a pretty good truck as is, I've owned both versions (sport and O/R) and would prefer the sport over the O/R and just throw in air lockers mainly because the sport has an 8.4" rear diff and the O/R has an 8". If you don't want the skewp you could swap it out with another member pretty fast and have some cash on top of it. :cool:
  14. Aug 7, 2014 at 3:54 AM
    Large
    Large Red
    If my 3rd ever gives out I will swap in a diamond or rock jock because fuck it.
  15. Aug 7, 2014 at 3:55 AM
    Ghost848
    Tony
    Alberta,Canada
    If all works out dana 60 right quick lol
    :stayontopic:
  16. Aug 7, 2014 at 4:03 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    If your truck is black are your around the NYC area I would be willing to swap scooped for non scooped hoods.
  17. Aug 7, 2014 at 5:19 PM
    TRD 13
    Spencer, WV
    Nope. Its Gray and Im in West Virginia.
  18. Aug 7, 2014 at 5:22 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    He lied!
  19. Aug 7, 2014 at 5:22 PM
    TRD 13
    Spencer, WV
    Wow! Is the 8.4 notoriously bad :confused:
  20. Aug 7, 2014 at 5:44 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    No, the 8.4 is the stronger of the two, maybe even as strong as a ford 9". The 8" e-locker is pretty tough though, just not as tough as the 8.4. I average about 40,000 miles on each 8" third (I've been through a few), running 37's and abusing the hell out of it. Like donuts on dry pavement with the locker on type of abuse. Just cruising up the holler slingin' mud that 8.4" will last you a very long time. (I used to live in chuck town).
