Question on installing a bypass
Discussion in 'Audio & Video' started by DecaturTide, Dec 13, 2013.
  1. Dec 13, 2013 at 8:21 AM
    DecaturTide
    DecaturTide [OP] Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    I know it's a simple three wire connection, but when connecting this to the appropriate wires on the harness, do you just tie the two harness wires and one of the bypass wires together with one connector? Or is there a special three wire connector?
    Thanks in advance.
  2. Dec 13, 2013 at 9:17 AM
    DecaturTide
    River City
    Any installers out there?
  3. Dec 15, 2013 at 7:13 PM
    FLTrucks
    FLTrucks Well-Known Member
    What are we trying to bypass?
  4. Dec 15, 2013 at 7:14 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I just used a relay.
  5. Dec 15, 2013 at 7:14 PM
    t4daddy
    North Alabama
    Sorry, the ability to play videos while moving.
  6. Dec 15, 2013 at 7:15 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    From the looks of that picture you are trying to bypass a parking brake signal. What I did was hook up my head units parking brake signal wire to a grounded toggle switch. All I have to do is wiggle it and it works. And a switch will never be updated out of the firmware.
  7. Dec 15, 2013 at 7:57 PM
    FLTrucks
    Some aftermarket units don't allow this.
    OP- You could use a relay to control it as it was stated earlier. What kind of Head unit is it?
  8. Dec 15, 2013 at 8:01 PM
    anders99
    Matthew
    Penscola, FL
    How would they not allow it. It would be exactly like hooking it straight to the parking brake wire.
  9. Dec 15, 2013 at 8:05 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    yea OP, that does the same as grounding the parking break wire... Please dont tell me you already bought that.
  10. Dec 15, 2013 at 8:07 PM
    anders99
    Matthew
    Penscola, FL
    Like what this guys said. But I know with my app radio 2 it needs to "feel" the brake on, off, then back on. Thats why I have the toggle switch. It makes the unit happy.
  11. Dec 15, 2013 at 8:08 PM
    FLTrucks
    Try doing that to some pioneer head units and it will still not work. Some are not integrated into just the parking brake however they also read the speed sensor.
  12. Dec 15, 2013 at 8:09 PM
    anders99
    Matthew
    Penscola, FL
    My pioneer app radio works with the toggle switch.
  13. Dec 15, 2013 at 8:11 PM
    FLTrucks
    Some will. I was just stating that some won't. This is why i asked what head unit.
  14. Dec 15, 2013 at 8:24 PM
    t4daddy
    North Alabama
    This is correct, at least for Pioneer heads, a relay eliminates the need to flip a switch, on, off, back on. YouTube is your friend.
  15. Dec 15, 2013 at 8:55 PM
    snowgod06
    Rob
    06 Access Cab
    true...but with the units that require the VSS wire to be used(like mine), you can usually swap the VSS wire in the harness to another spot and it works.
    OP, google your model of radio on how to bypass it. You will find theirs an easy way that doesnt require any parts!
  16. Dec 16, 2013 at 6:17 AM
    DecaturTide
    River City
    Thanks for all the answers guys.
    This is just a 20.00 part that automatically makes the head unit think that the parking brake is on, then off, then on, so there is no toggling. This part hooks to the black ground, the green parking brake wire, and the blue and white switch wire.
    This is for a Pioneer AVHX3500BHS.
    My main concern was connecting the 3 wires. The two harness wires and the bypass wire. Are there special connectors for 3 wires or can you just tie all three wires together with a connector.
    This bypass also is good for all firmware updates in the future.
  17. Dec 16, 2013 at 6:32 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You can tie them all together, there is no need for a special connector. Whatever you are using to tie two together, add the third in and you're good to go.
    For the others, the "module" bought is essentially a micro-relay and works great with that HU. Just grounding a Pioneer HU does not work, you need a relay or a toggle to get the on-off sequence right. The newer HUs also have to have a new module, since Pioneer added some more circuitry on the video lockout.
  18. Dec 16, 2013 at 6:38 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    I just tied all three wires together and capped them. The relay works great and I have had no issues since using it in my truck. No need to any special connectors.
  19. Dec 18, 2013 at 9:23 AM
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    On a Pioneer without navigation you have to wire a relay for the parking brake bypass. That is basically what you bought. You can use a toggle like mentioned above on a Pioneer but with a relay you don't have to flip a switch.
