Question on keys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AV8R_1951, Dec 2, 2023.
  1. Dec 2, 2023 at 10:06 AM
    AV8R_1951
    AV8R_1951 [OP] Member
    2022 White Taoma (plain Jane)
    Factory running boards
    I just bought a 2006, which came with two keys. One works the door lock and ignition just fine. The other only works the ignition. Not the door. Is this normal, or is there a chip in the key that has gone bad?
  2. Dec 2, 2023 at 10:12 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like the key may be worn, there is no chip to open the door aside from using the remote.
    Common for keys and ignition lock cylinders to wear at the same rate where they will still function together (until they won't) but the key may be too worn to operate the door lock cylinder which doesn't really wear much.
    GilbertOz likes this.
