Question on lift for 2wd 06 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soflasurfr, Dec 27, 2009.
  1. Dec 27, 2009 at 8:45 PM
    soflasurfr
    soflasurfr [OP] Well-Known Member
    Bilstien 5100's all around, OME 885 coils, AAL, Total Chaos UCA's
    I've read the stickies here on most of the lifts/wheel sizes but I want to make sure before I order the lift kit and tires it will fit.
    It seems the Bilstien 5100's don't actually give you a 3" lift, but a 2 and 1/2 and is it just front or does the back need to go up too? If those aren't right, what kind of lift will actually life me 3 inces? Most seem to limit the 2wd to 2 inch lifts unless I spend the $1000 for the 4 inch lift. I want to be able to fit some 33's with the 285/70-R17 size and i don't want to sacrifice too much on ride quality, etc.
    Thanks in advance!
  2. Dec 27, 2009 at 8:53 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You can run 285s with billy 5100s set at 2.5" but you'll have to do some major trimming. 5100s in the rear do not give you any extra lift...they give you extended travel :)
    Edit: But some Camburg 4" Spindles would be sick!!! Also, you might have some alignment issues with the lift so after market UCAs may not be a bad idea. Check out Light Racing if your on a budget or Total Chaos if money isn't that big of an issue :thumbsup:
  3. Dec 27, 2009 at 8:55 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    And Welcome to TW!! :wave:
  4. Dec 27, 2009 at 8:57 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    actually on my 2wd prerunner 4 door. i have 285/70/17 on the sport rims with no lift and only 1/4 inch wheel spacers up front and it barelly rubs
  5. Dec 27, 2009 at 9:03 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    So with those wheel spacers you still rub...
  6. Dec 27, 2009 at 9:04 PM
    johnw
    john
    orlando florida
    yes on sharp turns. and it aint even my body mount
  7. Dec 27, 2009 at 9:06 PM
    soflasurfr
    Hmm ok well i made and impulsive buy and bought front 5100's already. So that won't give it any real looking height? Can I still put the Camburg 4" Spindles with the front 5100's?
  8. Dec 27, 2009 at 9:12 PM
    johnw
    john
    orlando florida
    yes and just set the 5100's at zero
  9. Dec 27, 2009 at 9:13 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I say BS.
  10. Dec 27, 2009 at 9:14 PM
    sincitytaco
    Las Vegas
    Just buy the spindles and get the TSB leafs. You will sit about dead level and should be able to fit 285s no problem.
  11. Dec 27, 2009 at 9:21 PM
    johnw
    john
    orlando florida
    really your calling BS on me?
  12. Dec 28, 2009 at 8:17 AM
    soflasurfr
    So I wont need to do any spacing or additional modifications with the camburg 4". Also, this still only lifts the front right? Wouldn't it look odd to have 4" higher in the front?
  13. Dec 28, 2009 at 8:27 AM
    jonny
    jonny Betty White Edition Heep ZJ
    4" spindles + 5100's set at 0, tsb rear and possibly the tsb AAL to get that rear up. you shouldn't have any rubbing
    fwiw,
    i have 285's and 5100's set @2.5 and i had to do some minor trimming. nothing major unless your wheel your truck hard
