Question on LSD gear oil change HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfnWolf, Nov 15, 2008.
  1. Nov 15, 2008 at 9:40 AM
    SurfnWolf
    SurfnWolf [OP] Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    i have a 2006 double cab tacoma, just reached 30,000 miles, so im doing the maintenance.
    Went to the Toyota dealer and ask what gear they put in for the LSD.
    He showed me a quart fo 75W-140 Toyota synthetic gear oil for $25.00 dollars a quart.
    So I went to a near by Pep Boys, and they had:
    Royal Purple 75W-140 Max gear oil for Limited Slip for $13.00 a quart
    on the side it says contains Limited Slip Additive.
    The other was Mobil one 75w-140 ..seemed like the same specs..it had an LS on the front. but nothing really said contain Limited slip additive, it was 18.00 a quart.
    I went with the Royal Purple for the price, but I wanted more experienced Tacoma owners here to tell me , if this is the right gear oil.?????
    If you have time to comment...what do you think about changing the plugs to Iridiums? The service manager said I shouldnt, stick with copper, it was "engineered that way"?? Thoughts?
    Brian
  2. Nov 15, 2008 at 10:51 AM
    Joe B
    Joe B Well-Known Member
    Amsoil Severe Gear here in the diffs and transfer case with no problems.
    I would go Red line or Amsoil only but I don't think you'll have any problem with RP.
  3. Nov 15, 2008 at 11:59 AM
    SurfnWolf
    Fayetteville NC
    Well I was a little concerned, after reading here I should have used 7w-90, but I have already changed it with RP 7w-140? Can you see anything happening because of the heavier weight of 140?
    I live in NC.
    Brian
  4. Nov 15, 2008 at 12:03 PM
    Joe B
    I would go 75w90 even if I lived in NC.:)
  5. Nov 15, 2008 at 12:14 PM
    wes
    wes Well-Known Member
    Atlanta
    07 DC sport silver V6 auto
    URD CAI,URD Y-Pipe,,Wet-okle covers,Silverstar headlgt bulbs,Undercover bed cover,black nerf bars,Alpine 9883 Alpine speakers,Pioneer 10" sub,SIRIUS sat. Redline hood struts, white gauge led and shifter light "mod"
    I changed mine to Mobil 1 75-90w with LSD additive in it.The additive in the Mobil 1(syn) wasnt enough to keep the diff from chattering in a tight turn so I added an extra tube of Lucas brand LSD additive and have had no problems at all since(about 3000m ago).Bought it all at advance auto.
  6. Nov 15, 2008 at 3:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I used the Mobil 1 and all sorts of addatives, and my diff STILL made noise. I changed the fluid 3 times trying to find what worked best. I didnt try the Royal Purple, though. In frustration, I went with the OEM stuff, and it has been nice and quiet. :eek:
  7. Nov 17, 2008 at 6:37 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    I use syn everywhere but the LSD diff. CHeap dino or at most syn blend 80W-90(as stated in the manual) for LSD applications. 3 Q for $10-15. No issues.
  8. Nov 17, 2008 at 6:41 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    I went w/ OEM too. Last thing I want is noise.
  9. Nov 17, 2008 at 7:28 AM
    SurfnWolf
    Fayetteville NC
    What was the OEM stuff? as posted, the Toyota dealer handed me 75w-140 synthetic? Is that what you all put in?
  10. Nov 17, 2008 at 7:48 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    royal purple gear oil is great stuff it has the additive like u said already in it. u shouldnt have any problems.
  11. Nov 17, 2008 at 8:00 AM
    Joe B
    Some older Tacoma's have had noise with synthetic gear oil but the '09 will not have any problems using synthetic gear oil.Posi additive is also not needed.
    The '09 LSD is completely electronic and is unlike the former models with mechanical LSD.
  12. Nov 17, 2008 at 8:35 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    ^^^^ Yup.... but since you have an 06 you best go with regular dino with an LSD Additive....no chatter..... the best part is that you won't have any problems AND you didn't break the bank.
  13. Nov 17, 2008 at 8:41 AM
    brianr
    2010 4x4
    I am fairly sure that what it was. I can't go look b/c I threw the container away. :anonymous:
    So, whatever they gave me at the dealerships is what it got.
  14. Nov 17, 2008 at 9:29 AM
    SurfnWolf
    Fayetteville NC
    I just called another dealer in town about the gear oil, he said they recommend 80w-90..by the book but 75w-90 would be fine..BUT he said we only order by the barrel, we dont sell gear oil here!..lol Its a small town dealer near fayetteville.
