Question on new front wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baja Jones, Jul 25, 2018.
  1. Aug 10, 2018 at 10:38 AM
    turnerk1
    turnerk1 Well-Known Member
    Keith
    1996 4X X-Cab
    Mystery Lift
    Per a Toyota dealership tech, the black ring side goes toward the ABS speed sensor. So, for my 96 non-ABS, the black ring sides are going on the inboard side (towards CVs, away from snap ring). The photos above are interesting and seem to contradict this orientation. Maybe the orientation only matters for ABS vehicles and is also why the bearing style changed for some vehicles. I bet there's a mix out there.
    Edit: Follow up call with different dealership states there is no specific orientation.
  2. Aug 10, 2018 at 10:40 AM
    tony2018
    tony2018 Well-Known Member
    Scratches head, but you know what as long as you have those bearings in properly you should be fine.
  3. May 15, 2020 at 2:15 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    apparently the taco wheel bearings do not need re-packed greased at 150k
    they tend to need to be replaced a bit over 200k :notsure: :notsure:
