Question on OME Lift?
Discussion in 'Toytec Lifts' started by krisjw101, Feb 14, 2010.
  1. Feb 14, 2010 at 11:21 AM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    Hey guys, I really like to OME 3" lift and have heard that the ride is great on and off road. I want to lift my truck and really want to do it right in all aspects. The only thing that is stopping me from buying a lift today is I not want to hurt the truck, I dont want the shudder!!! I do notice that there are a few things that that come in the ultimate lift that dont in the OME (Swaybar relocates and shims). So basicly I want to know if i would need these for the OME kit? And to do a lift correctly are there any other parts or items that aren't in the OME kit I should get so that I dont have any issues? Also add any advice for a lifting new-b that might be helpful.
    Thank you,
    Kris
  2. Feb 14, 2010 at 11:25 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Solid choice by going with OME. I had the dakars and nitrocharger shocks on my old truck and loved them. They were great for everything from wheeling to working.
    The only reason my icons came with a relocation bracket is because they can't fit around the coilover (I think, I didn't reinstall the swap bar). If OME uses a smaller c/o they wouldn't have this problem.
    The only thing to really worry about with the OME lift is getting the right spring rate, after that it's all butter and running down kangaroos in the outback.
    When it doubt, go ARB is a pretty safe rule of thumb.
  3. Feb 14, 2010 at 11:26 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Not everyone gets the Vibes. The only thing aside from the kit I would suggest you get would be UCA's, check out fatbobsgarage.com, great price on light racing.
  4. Feb 15, 2010 at 1:55 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    The OME gear is nice!
    I would include the carrier bearing drop kit, I found that really helps a lot!.
    I would go with the 884's unless you have a double cab in which I would go with the 885's.
    (unless you plan on running a new aftermarket steel bumper)
  5. Feb 22, 2010 at 2:43 PM
    Gossamer
    Gossamer Howard Roark
    i have the 885s with my OME lift and there is barely a shudder about 5mph to 15 mph...other than that, it's great.
  6. Apr 29, 2010 at 8:02 AM
    dmbtiger19
    dmbtiger19 Well-Known Member
    Columbia, SC
    2010 Prerunner TRD SR5 Timberland Mica
    Can you please post EVERYTHING a person will need to purchase to gain a true three inch lift? I know I want the OME shocks on all for corners, the 885's up front and the leaf pack in the rear.
    If it helps, I drive a 2010 Prerunner.
  7. Apr 29, 2010 at 8:11 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    If yo get the 885 coils, you are probably going to need UCAs.
    Why not go with the 884s, and a 1/4 inch top plate spacer to gain some additional lift.
    i have the 884s without a top plate spacer and is about 2.5 inches of lift, no shudders or vibes, no UCAs.
  8. Apr 29, 2010 at 8:19 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    The 885s are 10mm longer than the 884s, so the need of a top plate would be unnecessary. Top plates are an additional $60.
  9. Apr 29, 2010 at 8:38 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
  10. Apr 29, 2010 at 2:52 PM
    Toytec Lifts
    Rocky Mountains
  11. Apr 29, 2010 at 2:54 PM
    Toytec Lifts
    Rocky Mountains
    But if he doesn't have the weight to support it, his ride will be stiffer.
  12. Apr 30, 2010 at 5:50 PM
    DTRD
    DTRD Well-Known Member
    Derrick,
    I have a 97 Tacoma 4x4. I installed the Toytec front coil over with the OME cs019r rear leafs with third leaf from the bottom ( is this correct) removed. Very rough ride so did I remove the right leaf ( the thick one third up) per Toytecs suggestion? After the install, I have severe vibrations at take off to 30 mph. When coasting at higher speeds I hear rattling for a moment when letting off the gas.
    In need of severe help. I can not remove the third leaf down due to it being the leaf with the spring keeper loop riveted in.
    I asked an ARB tech. Nils Bull and here is his response(
    You've removed an overload leaf from each pack which hasn't changed the
    primary spring rate of the pack and therefore hasn't changed the ride
    quality or the height of the truck. The secondary, or overload, rate has
    been changed which doesn't come into effect until after the arched
    leaves flatten out with a heavy load in the truck. Additionally, if the
    truck does end up carrying a heavy load there is no long overload to
    support the rest of the pack and the arched leaves will be bent
    backwards over the remaining short overloads and consequently damaged
    beyond repair. The overload leaves must be put back into the packs.
    The proper leaf to remove is "the third leaf down", meaning count the
    top leaf as number one and count down to number three. In the case of
    the CS019R it will be the bottom arched leaf. The vibration issues
    should go away once you lower the truck by removing the correct leaves.
    Part of the harshness you're feeling, although you will be better able
    to judge this once the correct leaves are removed, is likely due to the
    Bilstein shocks. Bilstein's are a high pressure monotube shock which
    translates to a much firmer ride then a comparable low pressure, dual
    tube, shock such as OME. Additionally, The Bilstein is likely not valved
    correctly for your particular vehicle but instead selected based on open
    and closed lengths and mounting style. OME shocks are valved
    specifically per application and spring rate thus offering a premium
    ride quality over most other brands.
    Best Regards,
    Nils Bull
    ARB Tech
    nilsb@arbusa.com
    ph. (425)-264-1391
    ph. (888)-4ARB-USA
    fax (425)-264-1392
  13. May 5, 2010 at 7:26 AM
    Toytec Lifts
    Rocky Mountains
  14. May 27, 2010 at 7:32 AM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Thanks for posting that response from ARB. OME's are sounding better and better to me.
