Question on Painting Steel Bumper
Discussion in 'Armor' started by KaptainH, Aug 23, 2017.
  1. Aug 23, 2017 at 4:27 AM
    KaptainH
    KaptainH [OP] Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Going to be painting my bare steel bumper soon. I plan to use VHT RollBar and Chasis paint, satin finish. It claims it is a one step ester epoxy which doesn't require a primer.
    My question is should I use a primer still, and if so what type of primer. My go to would be self etching rustoleum but this is a different type of paint than the epoxy I'll be using.
    I tested on the under sides of my skid and love the finished look so far. I just want the job to last. Going with rattle can paint so it's easy to touch up.
  2. Aug 23, 2017 at 6:38 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    I used the same paint with primer and it worked well but it did fade over time and ended up repainting with rustoleum later. I did not paint it with a clear coat at the end so I'm sure that would have made a difference.
    creedance likes this.
  3. Aug 23, 2017 at 6:40 AM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I would use a etcher primer. 1 or 2 coats. Then the paint you want. I did all my skids and sliders.
    tony453rd likes this.
  4. Aug 23, 2017 at 6:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    You might consider a bedliner product.
    One that is very durable and has a smoother finish than any with the rubber chip stuff is www.monstaliner.com
    Look around at their gallery. You might like it.
  5. Aug 23, 2017 at 2:49 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    If you off road AND like to keep it looking decent, go with something that you can touch up 1/2 way easy....
    KaptainH[OP] likes this.
  6. Aug 28, 2017 at 1:41 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Be sure to prep the metal as well. A good wipe down with acetone, scuffing with steel wool and another wipe with acetone goes a long way helping the paint stick well. I did my bumper and sliders with a coat of self etching primer, a coat of black rustoleum and a couple coats of black rustoleum bedliner. It's held up well and is super easy to touch up when needed, a few light sprays of bedliner over any scuffs and it blends right back in.
    InfernoAlt and tony453rd like this.
  7. Aug 28, 2017 at 1:29 PM
    KaptainH
    Kris
    Gainesville, GA
    I used dish soap and pressure washer, scuffed, and then wiped with acetone.
    Contacted VHT and they said don't use any primer. It's been painted. Gonna wait 7 days for cure and then use 400grit and paint one more coat with a little more finesse.
    Thanks folks!
