Question on pre-loading shocks
Discussion in 'Suspension' started by shooter3225, Jan 22, 2012.
  1. Jan 22, 2012 at 3:38 PM
    shooter3225
    shooter3225 [OP] Well-Known Member
    Tyler
    Riverside, CA
    09 TRD PreRunner
    So I'm looking at getting fox c/o's and TC uca's for my truck with dakars/ap expos in the back (can't decide), and I want my truck to sit as level as possible. My understanding is that when the c/o's are set at 2.5" they ride very stiff and rough off road, is that right?
    I've been looking at TC spindles as well and if I put on the spindles I can set the shocks at 0 and still have a 3" lift correct? And that would ride a lot smoother off road with more travel?
  2. Jan 22, 2012 at 4:48 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    The shocks are designed to operate best at 2.5-3" lift....higher than that they ride like shit. The spindles are nice because you can take the preload out and it will be smoother!
  3. Jan 22, 2012 at 4:52 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I would 110% recommend, if you have the money, to go with the Camburg spindles. You want the truck to sit level? If you lift 3 in the front and rear (expo's give 3") then you will still have a rake.
    Spend the money on the spindles and your going to be ok with the factory coilovers and upper arms. You need to take into consideration as well if you preload a coilover to 3" then you will need aftermarket Upper control arms to align the suspension.
  4. Jan 22, 2012 at 5:45 PM
    shooter3225
    Tyler
    Riverside, CA
    09 TRD PreRunner
    I go offroad pretty often so I'm going to replace the factory c/o's with fox c/os with resis and go with TC uca's.
    My question tho is for on road/offroad performance, is it a better ride and more travel if I set the fox c/o's at 0 and then run spindles. Or will I be fine with just the c/o's set at 2.5 or 3"
    Also is there a big difference b/w the TC spindles vs cb spindles because I have been looking at the TCs
  5. Jan 22, 2012 at 6:04 PM
    08pretaco
    az
    i was running fox extended travel coilovers ~1" with tc upper arms with the camburg spindles....off road it was wonderful!
    If you have the coin and wheel a lot, spindles with uniball upper arms and a great set of coilovers will make for a great solid wheeling set-up!
    Biggest difference between the 2 is cost. Burg is 1000 compared to 1400 IIRC. They are basically the exact same thing, one offers a little more lift. I can vouch for the Burg spindles as we install them all the time and they are by far one of the best ways to solidify your suspension and lift the truck.
    Your going to have a much smoother ride off road if you do spindles and leave the coilovers at 0", be it whichever company you go with!
  6. Jan 22, 2012 at 6:20 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    That's what I'd do if I was 2wd and wanted the best ride possible!
  7. Jan 22, 2012 at 8:09 PM
    shooter3225
    Tyler
    Riverside, CA
    09 TRD PreRunner
    Ok sweet thanks bro that's what I thought I just wanted to be sure! That's the set up I want to run so good to hear some positive reinforcement :D
  8. Jan 23, 2012 at 6:40 AM
    08pretaco
    az
    When you order the apindles make sure you call Jeff at Camburg to get your TW discount.
  9. Jan 23, 2012 at 12:20 PM
    shooter3225
    Tyler
    Riverside, CA
    09 TRD PreRunner
    Hell yea for sure..yea I wasn't sure if I wanted to go with the camburg or the TC spindles but if they're pretty much the same, might as well save a few hundred dollars.
