Question on replacing the cylinder head 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DumpsterJedi, Sep 5, 2022.
  1. Jun 27, 2025 at 12:25 PM
    #41
    SiskiyouSavage
    SiskiyouSavage Member
    Rob
    1998 Black 2.7 Standard Cab 340k
    Update, OP? What did you figure out? I'm about the start my head gasket job.
  2. Jun 28, 2025 at 10:59 AM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You probably won't get an answer as the OP hasn't been seen in a while:
    DumpsterJedi was last seen: Nov 20, 2022
    Torspd likes this.
  3. Jun 28, 2025 at 2:35 PM
    #43
    TJTM
    TJTM Active Member
    2009 2.7 l, 4x4 access cab
    I agree with this. The FSM lays out the spec that determines whether they can be reused.
    Also, FYI I've had problems using Fel Pro headbolts. Torquing them to spec resulted in a couple of the bolt heads cracking. This was in a matrix but the warning applies.
  4. Jun 28, 2025 at 2:39 PM
    #44
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I could be wrong but I think some of the Rav4s and Matrix had problems with threads getting pulled out of the block?
  5. Jun 28, 2025 at 2:48 PM
    #45
    Bishop84
    Bishop84 Well-Known Member
    The 2nd gen rav4 2.0
    I have dodged the bullet on that job so many times, no idea how. I've watched techs absolutely struggle with the threads in the block. Righty tighty is righty loosey
    Same with 5.4 spark plugs, I never broke a single one. I had a pretty good method and they were still only 5-7 years old max. Now I'm sure they are all breaking but at the time of my apprenticeship I had the golden touch.
    b_r_o[QUOTED] and Steves104x4 like this.
  6. Jun 28, 2025 at 2:58 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I saw a couple Rav4 with external coolant leaking down the back, soaking that piece of foam under the intake.
    I told them complete engine or im not touching it haha
    Torspd and Bishop84[QUOTED] like this.
  7. Jun 28, 2025 at 3:03 PM
    #47
    TJTM
    TJTM Active Member
    I've heard that too. Didn't happen in my case, though.
    The bolt head cracked when the last 90 degree turn was made. This only happened with two of the bolts but it made me suspect that they weren't made properly
    I've done quite a few head gaskets in various motors so I was torquing the bolts to the proper torque and using nice smooth pulls.
    b_r_o[QUOTED] likes this.
  8. Jun 28, 2025 at 3:05 PM
    #48
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I do a lot of subaru heads and some head bolt kits suck. The threads look like they've been shaken up in a bucket with a bunch of other bolts. Dented, bent, etc
    I started going dealer only
