Question on Rocker Switch Amperage and Voltage
Discussion in 'Technical Chat' started by Tunngavik, Aug 24, 2011.
  1. Aug 24, 2011 at 3:55 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I would like to install heated seats in my truck and with that would like to install an on-off-on rocker switch.
    From what I’ve read online from various people who have installed the seats, the seats take between 3-5 amps each and are typically hooked up under to a 10 amp fuse in the box to the lower left of the driving column.
    Now here is my question, I found some rocker switches that maybe would do the trick (look good, fit in the space I want them to, and are 3 post) but I’m not sure if they will work electrically. The rocker switches have the following values – 18A 125VAC and 10A 277VAC. Do you think these will work considering the amperage required for the seats and the 12V battery of the truck?
