Question on the OME suspension lift..
Discussion in 'ToyTec Lifts' started by Fienoma, Jun 9, 2009.
  1. Jul 5, 2009 at 9:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Stock brake lines are fine, and you shouldnt need to do anything with the sway bar. :)
  2. Jul 5, 2009 at 9:12 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Yes, +1. You will not have to move the sway bar with the OME kit but will have to with the 5100 coil overs because the lower sleeve will hit the sway bar. This is why the 5100 kits come with sway bar relocation brackets. Oh the OME kit is front adjustable with a trim packer.
    http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
    One of these is included in the OME kit. :)
  3. Jul 5, 2009 at 9:35 PM
    Fienoma
    Fienoma [OP] Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    lol i'm sorry for asking so many questions but whats the front adjustable trim package?
  4. Jul 5, 2009 at 9:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a "Trim Packer". It adds a bit of preload to the driver side spring to account for the extra weight from the fuel tank, battery, driver, etc.,
  5. Jul 6, 2009 at 7:21 AM
    Neubs
    Maryland
    Chris, you are the man, on top of everything like white on rice. :) Here is a picture of a trim packer.
  6. Jul 6, 2009 at 7:37 AM
    Incognito
    Incognito μολὼν λαβέ
    Colton
    VA
    2012 Pyrite AC TRD OR
    See Build thread
    Are UCA's necessary for a 3'' lift?
    I'm pretty sure that with Billy's set at 2.5 that UCA's wouldn't be necessary, am I correct?
    Sorry, :threadjacked: :eek:
  7. Jul 6, 2009 at 7:41 AM
    Neubs
    Maryland
    UCAs are strongly recommended to help obtain a good alignment. They also increase strength and articulation. You can use stock UCAs with a 3" lift but as a result you will have less than optimal caster and the truck will want to wander.
  8. Jul 6, 2009 at 7:54 AM
    Incognito
    Colton
    VA
    See Build thread
    Thanks for the reply, Nuebs. :) Would there be any decent UCA's for under $500? I have seen the TC UCA's and they're a bit expensive. Could you recommend me some decent one's for a good price? Thanks again. :)
  9. Jul 6, 2009 at 8:09 AM
    Neubs
    Maryland
    The Light Racing UCAs are being sold though the ToyTec Group Buy at a seriously low price. I sent you a PM with the details. :)
  10. Jul 6, 2009 at 11:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, Camburg has an UCA that uses Ball joints as opposed to Uniballs, and I belive it is under $400.00.
  11. Jul 7, 2009 at 11:41 AM
    Fienoma
    Hieu
    New Mexcio
    one more question lol..sorry but is the optional top plate spacer needed to get a full 3" lift?
  12. Jul 7, 2009 at 11:43 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yes...That's the idea.
  13. Jul 22, 2009 at 2:57 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    where does the trim packer go?
  14. Jul 22, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Under the spring pearch on the driver side shock.
  15. Jul 22, 2009 at 4:19 PM
    #35
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    spring perch = lip on strut that holds the lower plate?
  16. Jul 22, 2009 at 4:20 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The spring pearch is the black "Cup" in which the spring resides. So....You have the shock, and the shock has the "lip" that holds the pearch. The Trim Packer goes inbetween the "lip" and the "Pearch". :)
  17. Jul 22, 2009 at 4:22 PM
    #37
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    gotcha, thats what i thought...your the man chris, if i could mail you a beer from the bar i would
  18. Jul 22, 2009 at 4:23 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I got one in the fridge. I'll throw a stamp on it, and pop the top. :D
  19. Jul 23, 2009 at 12:52 PM
    #39
    cdnbanker
    cdnbanker Well-Known Member
    can you add both the trim packer adn the spacer?
  20. Jul 23, 2009 at 12:52 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    By "Spacer" you mean the 10 mm lift enhancer?
