Question on Tire/Wheel Size *Help*
Discussion in 'Wheels & Tires' started by Ghumps, May 2, 2012.
  1. May 2, 2012 at 10:31 AM
    Ghumps
    Ghumps [OP] Well-Known Member
    I just had put in a Billstien 5100 Leveling Kit on the front of my truck, Wheels and tires are next, I am thinking about running some 265/75/R16, I think they are around 31.6 Inch tires, whats the best wheel size I should go? 16 inch or 17 inch wheels?
  2. May 2, 2012 at 10:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Welcome to TW!
    If you're going to run 265/75R16, I'd suggest using 16" rims :D
    Honestly, it doesn't really matter. If you go 17's, you can go with 265/70R17.
  3. May 2, 2012 at 10:42 AM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    im going to be getting that size on my 16.. i know a few years ago, getting that size on 17s was way more expensive... 3 years ago my brother got that size tire on 17s,= $1,100. Im getting that size in a week or two on 16s, =$800 i dont know now about 17s, but i would look up the price of each size and see where you want to go from there.
  4. May 2, 2012 at 10:56 AM
    Ghumps
    Thanks for the help, I have two friends with Tacomas and they are telling me different things, one says I should get 17's because if I get 16's I have to get a spacer and the wheel will pertrude out which I am not really looking for.
  5. May 2, 2012 at 11:50 AM
    Ghumps
    So would a 16" rim require me to add a spacer?
  6. May 2, 2012 at 11:54 AM
    Pugga
    Massachusetts
    No, you won't need a spacer if you get rims with the correct backspacing.
  7. May 2, 2012 at 1:17 PM
    Ghumps
    Ok, what would be the correct backspacing?
  8. May 2, 2012 at 1:34 PM
    Pugga
    Massachusetts
    Check out these threads. If you get the same specs as the stock wheels, you shouldn't have any problems with rubbing. If you make the stick out too far, they'll rub your fenders, in which case spacers would make it worse.
    http://www.tacomaworld.com/forum/wheels-tires/102992-wheel-backspacing-offset-info.html
    I'm trying to find the stock offset and backspacing specs now. Where's KPT when you need him?!?! He's the one that knows all about this stuff!
  9. May 2, 2012 at 1:53 PM
    Ghumps
    [QUOTE=Pugga;5027414]Check out these threads. If you get the same specs as the stock wheels, you shouldn't have any problems with rubbing. If you make the stick out too far, they'll rub your fenders, in which case spacers would make it worse.
    Appreciate it, I think im gonna go with 265/75/R16. Keep it simple, Ill post pics when its all done!
  10. May 2, 2012 at 1:58 PM
    Pugga
    Massachusetts
    If you have backspacing questions, PM member KPT. Keith knows his stuff!
