question on u bolts
Discussion in 'Suspension' started by jnix7, Apr 3, 2010.
  1. Apr 3, 2010 at 9:07 PM
    jnix7
    jnix7 [OP] Member
    Jamie
    Cleburne, Texas
    07 DC TRD Auto
    Billies set @ 1.75 BHLM, Fog light mod, 2 Hella 500ff's behind front grill. ddm 35w 5000 headlights and 35 w 4500 fog lights Grillcraft mx upper and lowers
    Just wondering if i need longer u bolts when i do an aal? I have the 3 spring w/out tsb. The aal's will be 2 inches. Any help would be greatly appreciated.
  2. Apr 3, 2010 at 9:09 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    yea you will...make sure they fit correctly. Installed my aal and 3 of the 4 fit...aka road block
  3. Apr 4, 2010 at 12:43 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You might be able to re-use them but it is recommended to use new bolts. As long as the threads aren't mangled on your current U-bolts I'd probably reuse them. But then again it would suck to put on the AAL only to find your Ubolts are too short.
  4. Apr 4, 2010 at 12:45 AM
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    i just used the same u-bolts. theres only one thread showing though, but i dont mind.
  5. Apr 4, 2010 at 6:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'd highly recommend using new u-bolts.
    If you use the original u-bolts, you should check them regularly to make sure they're staying tight. Used ubolts don't always stay tight like new ones do. If you don't check them, they can cause more damage in the long run (broken centerin pins, & leaf pak coming loose).
