question on vibration...
Discussion in 'Suspension' started by Bandittaco, Sep 16, 2011.
  1. Sep 16, 2011 at 2:58 PM
    Bandittaco
    Bandittaco [OP] Member
    Ernie
    mission tx
    2011 sport prerunner 4x4
    5100s set to 2.5 in front 5100 in rear with aal,weather tech floor mats,putco led interior kit, swl flush mount tool box, n-fab steps
    i have a 2011 tacoma with the readylift sst kit the 2.75 in the front and the 2" block in the rear... I also installed some bfg all terain 265x70xr17 tires on the stock wheels when I take off from a dead stop i feel a slight vibration and then it goes away it does it from about 2 to 5 mph... any ideas what i can check out or if something needs to get changed out thanks in advance...
  2. Sep 16, 2011 at 3:01 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    you need 2 degree axle shims and put them in with the fat part forward so it shims your rear axle down. when you have a u joint axle, you want the angle at your tranny and the angle at your rear diff to be opposite to cancel eachother out. also turn your blocks around or get rid of them for AAL's but they are cut with a small inclination to shim your axle also. pickin up what im puttin down?
  3. Sep 16, 2011 at 3:08 PM
    Bandittaco
    Ernie
    mission tx
    so i just install 2 degree shims with the thick part facing foward and that should take care of it..
  4. Sep 16, 2011 at 3:37 PM
    650H1
    Michael
    VA
    should take care of it, also turn the blocks around if you plan to keep them.
  5. Sep 16, 2011 at 3:41 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Shouldn't the fat part of the shim be rearward, to reduce the angle caused by the lift?
    I've not done it, so I really don't know... that's just what makes sense in my head.
  6. Sep 16, 2011 at 5:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This ^^^
    Fat end to the rear
  7. Sep 17, 2011 at 11:15 AM
    Bandittaco
    Ernie
    mission tx
    I was under the truck and the block is cut like a shim on one side but the fat part is facing rear should I turn them around and try it out????;
