Question regarding an AAL
Discussion in 'Suspension' started by pivey14, Jan 22, 2013.
  1. Jan 22, 2013 at 7:47 PM
    pivey14
    pivey14 [OP] I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
    I'm wanting to put 5100's all around with the front Billies set @ .85 with Eibach Coils. This should give me 2.5". I only have 3 leafs in the rear. If I add a fourth leaf (Toytech TSB 1.5") will it level my truck? Will it sag and make my truck "bro lift"? Thanks for any help
  2. Jan 22, 2013 at 7:50 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Should be about level or slightly higher in the rear, you could go with 2" AAL if you are worried about the nose being to high
  3. Jan 22, 2013 at 7:52 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Gotcha, Thanks.
  4. Jan 22, 2013 at 7:53 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    are the Toytech TSB 1.5" AAL known to sag?
  5. Jan 22, 2013 at 7:54 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    ^^^This. I went up 2.75" in front and put a 1.5" Wheelers 3 leaf prog AAL on a non-TSB rear and I've got .25-.5" of rake. I left the overload in.
  6. Jan 22, 2013 at 7:57 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    How do your stock leaf springs look? Because they will sag over time probably, mine stock springs sagged very fast from carrying heavy loads. So i went with dakars over AAL
  7. Jan 22, 2013 at 8:05 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Mine did. I had to add a 1" block to keep the truck from being higher in the front with 885's on 5100's in the front (2.5ish inch lift)
    Edit: And i never had anything more than a small portable toolbox and mountain bike in the bed.
  8. Jan 22, 2013 at 8:12 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I may just step up to the 2" AAL and let it just settle for a little rake.
