Question regarding bilstein 5100's in order to LEVEL my 2012 taco DCSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Aug 14, 2012.
  1. Aug 19, 2012 at 4:14 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    here is some pics of my truck with the bilsteins set at .85 inch. let me know what you all think, like i said, about an inch in ride height from front to rear after the install :eek:
    Front: 35.5 inches
    Rear: 36.5 inches
    ChadsPride likes this.
  2. Aug 19, 2012 at 4:21 PM
    Larry
    Larry CARL
    CARL
    the truck looks good.
    but really, to answer the OP...one must define "level".
    is level the pinchweld off the ground f&r?
    is level the top of the bedside?
    is level the edge of fenders above ground?
    edge of fender above center of hub?
    personally, I believe with stock rear springs or TSB or Toyota 4-pac...5100's @ 1.75 is pushing the bro look.
  3. Aug 19, 2012 at 4:30 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    yes, i agree that 1.75 is pushing it lol, thats why i set it at .85, thank you, i appreciate that you like it, and same to you :eek: I measured in 4 different spots originally, on a level surface from the floor to the rockers (pinch welds) from the floor to the fender, from the center cap to the fender, and from the top of the tire to the fender and took a look at the measurements then took the average of those measurements :)
  4. Aug 19, 2012 at 4:47 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Front looks lower.
  5. Aug 19, 2012 at 5:01 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    yes, its 1 inch lower, but like i stated b4, if i went any higher i woulda had UCA clearance issues and the truck is supposed to have a slight rake, the valving and ride quality improvement is a massive plus all by itself lol
  6. Aug 19, 2012 at 5:16 PM
    Taco-NB
    New Brunswick
    2.5 on my truck with a 5th AAL on the rear. No UCA clearance issues here. I'm not saying it looks bad .... but it definately looks lower in the front.
    Cheers :D
  7. Aug 19, 2012 at 5:48 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    It's basically an aal from Toyota to compensate for the weak leafs.
  8. Aug 19, 2012 at 5:52 PM
    TacoDawgfan
    Georgia
    That is where I'm trying to decide on this. Not that I will do anything soon, but do want to make up my mind. I know a member on here did the TSB and billy's at 1.75. He later added I believe 1" blocks to the rear to level it back out. So If I did go 1.75 I'm not sure how much lift the rear would need.
  9. Aug 19, 2012 at 7:33 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Thank you again ,:) and i know its alittle lower in the front but im kinda happy it is, i took the safe route lol, and oh my bad, i meant uca clearence issues at full extention.only like when the truck is up in the air xP but yes, thank you very much again :))
  10. Aug 19, 2012 at 7:44 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Hmm well do u happen to know what years that tsb is for?? Cause if its to correct weak rear leafs im.sure toyota took care of that issue by now, i mean my truck is a 2012 and this tsb sounds like its been.around for alittle while, so im.sure its fixed in the new models, and i also have the overload spring from the towing package witch im sure only adds to the integrity, not that i tow anything tho lol. But yeah, from the way i see it, if u set it at .85 u get a mild leveling lift from it, leaving the front slightly low and you wont have to touch anything in the rear, and the 1.75 will leave you slightly nose high making you have to add something to the rear such as the aal or a block to bring it up so it looks right with the front. :)
  11. Aug 19, 2012 at 8:07 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This picture shows you already have the post-TSB leaf pack with 4 leafs. Pre-TSB had 3 leafs. The TSB has been around for several years, but Toyota only began to productionize it in 2012 trucks.
    Seems like you went thru a lot of trouble just to raise the front by 0.85". :p
  12. Aug 19, 2012 at 9:38 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Haha wow really?? I had no clue, honestly, i just thought that was all part of the tow packagelol, well good stuff then :) and yes i did go through alot, hours and hours of research and debating but it was worth it :D
  13. Aug 20, 2012 at 3:04 AM
    TacoDawgfan
    Georgia
    I thought the 12's had the 4 leaf already but didn't want to say w/o knowing for sure, should have looked at the pics closer.
  14. Aug 20, 2012 at 7:37 AM
    Larry
    Larry CARL
    CARL
    I'm gonna go to the same trouble.
    the approx one inch front lift puts the truck that has the 4-leaf pack rear to a factory stance of most new 6-luggers.
    when I had my 2010 SR5 and had the TSB done...rear lifted a little over one inch. my 2012 Sport has the 4-leaf and has approx the same dimensions as the 2010 post TSB.
  15. Aug 20, 2012 at 2:55 PM
    #35
    kyleTRDtaco12
    Kyle
    New Jersey
    Sounds to me like toyota did some tweaking on the 2012 6 luggers lol but only those with the tow package, cause the ones without the tow package and with the 4 cylinder engine do not have the 4th leaf lol
  16. Aug 20, 2012 at 2:58 PM
    #36
    Larry
    Larry CARL
    CARL
    the 4-leaf pack was standard on trucks built for most countries except US prior to 2012.
    I guess Toyota got wise and realized most Tacoma buyers were not buying a grocery getter like most mid size American truck buyers who probably would be better served w/ an SUV...
  17. Aug 20, 2012 at 3:10 PM
    #37
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Just curious how much this cost you in the end? I have an SR5 that I would like to do a little light off-roading with. Not sure the stock shocks are really built for that and am hoping this would be a fairly cheap way to make it ride a little better off road without really changing to on-road ride too much.
  18. Aug 20, 2012 at 4:07 PM
    #38
    kyleTRDtaco12
    Kyle
    New Jersey
    well first off, let me say, thats a nice truck and i love the the wheels, 2nd, the 5100's are just what ud be looking for, the ride quality is unbelievably good and they offer a decent level/lift witch still keeps the trucks original functionality. if u get a whole set like i did, the fronts are about $125 a piece and the rears are about $90 a piece for a total of $430.00 plus tax for all four (witch id suggest)... if you dont install them yourself its about $660.00 in labor and a $75.00 4 wheel alignment :)
  19. Aug 20, 2012 at 4:16 PM
    #39
    bjboucher
    Brad
    San Antonio, Texas
    Thanks, it was the wheels that sold me on this truck! lol I need to find a handy man to help me put on some shocks. I would do this for about $500 but another $660 on top for labor is a bit much. Would be tough to convince the wife. Thanks for info.
  20. Aug 20, 2012 at 4:23 PM
    #40
    Larry
    Larry CARL
    CARL
    I paid less than $300.00 from Down South Motorsports for all 4.
    (I just pulled my reciept, $299.99 - $17.00 TW forum discount = $282.99, free shipping. This was a year and a half back)
    and no way I'd pay $660.00 in labor to have them installed. The rear is an hour job I can do myself w/o even removing the rear wheels.
    The fronts are more work...maybe worth a few hundred, 200-300 Tops.
    yes, an alignment will go about 70-100 bux.
    :cheers:
