Question regarding engine start....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jun 20, 2024.
  1. Jun 20, 2024 at 6:35 AM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    So it's been nearly six months since I was last able to start my Tacoma.
    I'm concerned about the lack on engine oil in the top of the engine, so prior to starting I was planning on disconnecting the crank shaft position sensor, and motoring the engine of the starter until the oil pressure light goes out (about 30 seconds I would think). Then waiting about a minute or so, reconnecting the sensor and then starting it.
    My question is 2 parts:
    1a) Should I change the oil before starting? I use 5w-30 full synthetic and the current oil in the engine had about another 1000 miles before being due for a change.
    1b) If so, should I change it before or after initial start and warm up?
    2) Should I pull the spark plugs and pour some oil down the holes the night before?
  2. Jun 20, 2024 at 6:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    1) Do you have any reason to suspect contamination while sitting? If everything was capped and sealed Id run it. But an oil change isn't expensive if it makes you feel better to just do it now.
    2) No.
    kidthatsirish[OP] likes this.
  3. Jun 20, 2024 at 7:08 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just check the oil level and run it. It's not a delicate flower
    I'd be more worried about stagnant gas in the tank than a lubrication issue. Throw some Heet in there and give it a whirl
    kidthatsirish[OP] and Dm93 like this.
  4. Jun 20, 2024 at 7:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't worry about it but if you want to crank it over first without it starting the simplest thing would be to pull the EFI Relay.
    I'm with @b_r_o 6 months isn't that long, if you have issues with anything it would be the fuel because our shitty gas doesn't have a very long shelf life.
  5. Jun 20, 2024 at 7:32 AM
    kidthatsirish
    Yeah the fuel is something I'm a smidge concerned about.....only had about a 1/3 of a tank in.....so thinking about putting in a dose of techron before I put gas in it.
  6. Jun 20, 2024 at 11:44 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Six months? IN A ROW?
    I started up my F350 after sitting 6 months.
    Taco be started up soon after sitting 2 years. Frame replacement time.
    JD 420 sat 7 years and fired right up after carb cleaning
    JD 430 sat 2 years and fired up, sitting for 7 now and ill start it up soon.
    KDX sat 3 years and started up after 2nd kick
    IH sat for 10 years in a field and started right up after carb clean.
  7. Jun 20, 2024 at 12:24 PM
    545 Well-Known Member
    2015 Access Cab
    Fuel delivery does not affect oil flow
    Just start it
  8. Jun 20, 2024 at 12:28 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    geeezus...unplug the crank position sensor? on what planet did this seem like a good idea or even an idea?
    just start it. oil will be at the top of the engine in less than 2 seconds. There is enough residue for the start.
  9. Jun 20, 2024 at 1:23 PM
    kidthatsirish
    When installing a new/dry engine, the procedure calls for disconnecting the crank position sensor to prevent actual ignition, motoring the engine until the oil pressure light goes off, then reconnect the sensor, then starting the engine.
    But it sounds like most think this is overkill for my engine that has sat six months....good to know.:rofl:
  10. Jun 21, 2024 at 6:54 AM
    knottyrope
    Knotty
    Bahstun
    its not a new engine and doesnt need to do that
