Question regarding H4 4x4 setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meegari, Nov 16, 2010.
  1. Nov 16, 2010 at 9:22 AM
    meegari
    meegari [OP] Well-Known Member
    Tacoma TRD Sport SB Leather Pkg
    Today is the first day I had to use my H4 (first snowfall), my question is probably very silly but can I leave it in H4 and turn the ignition off?
    I also have a remote starter installed would this be effected in any way?
    Also as long as I drive under 100kmh can i just leave it in H4?
    Thanks for your help team.
  2. Nov 16, 2010 at 9:23 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Yes, you can turn the truck off with H4 engaged. And yea, you can drive it as long as you are on snow, dirt, etc. Just don't leave it on while on dry pavement.
  3. Nov 16, 2010 at 9:33 AM
    meegari
    Thanks 1337!! I wish we had dry roads :(
  4. Nov 16, 2010 at 9:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Even wet roads don't really provide the kind of slip needed to avoid damage. I would only use it if you need it.
  5. Nov 16, 2010 at 9:38 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    I agree. I wouldn't use it on any pavement. Just Snow, Sand, Rocks, and Dirt/ Mud.
  6. Nov 16, 2010 at 9:51 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    fixed it for ya:)
  7. Nov 16, 2010 at 9:52 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    100 km/60 mph is max speed to shift from 2H to 4H.
    There is no speed limit locked in 4H, its same as 2H... hitting the governer around 110 mph.
  8. Nov 16, 2010 at 11:58 AM
    meegari
    Im in Calgary Canada, and they dont do a great job of cleaning the snow around here.
    Thanks for the tips guys!!
    Appreciated!
