Question Regarding High Angle CV Boots
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomadude89, Apr 27, 2012.
  1. Apr 27, 2012 at 8:04 AM
    Tacomadude89
    Tacomadude89 [OP] Well-Known Member
    Austen
    So I am planning on replacing my stock CV boots with a set of high angle design.
    My question is, I can only find the ones that are listed for the outer. Is the outer boot considered the one closest to the differential? The ones that I will be replacing are the upper ones (the ones closest to the diff) and need to if these are the ones that will work. http://www.lowrangeoffroad.com/index.php/tacoma-4runner-long-travel-outer-c-v-boot-and-clamp.html
    If it's vice versa instead and the uppers are actually considered the inners, where can I find the high angle/long travel boots that fit the inners? Or, maybe these aftermarket type fit both sides. I wish I knew more here.
    Thanks in advance.
  2. Apr 27, 2012 at 12:10 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Not sure but outer would mean to me the closest to the wheel. Inner the differential.
  3. Apr 27, 2012 at 12:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Outside boot closer to wheel, inside boot closer to front diff....;)
  4. Apr 27, 2012 at 12:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Both a PITA to do.... c'mon SAS, please...:D
  5. Apr 27, 2012 at 1:00 PM
    Tacomadude89
    Austen
    If it were only that easy. :rolleyes:
    Thanks guys.
    Do any of you know by chance of a place to buy the inner high angle boots then? Honestly, all of the places that I've been able to find so far that sell these list them as the outer which I think is a little strange considering the fact that most of the problems occur with the upper boots instead, so you'd think the market for them would be for those instead. Anyway, until then, I'll keep on researching my options.
    Thanks again guys.
  6. Apr 27, 2012 at 1:12 PM
    FailRated
    FailRated RTO
    Evan
    Maryland
    03 Double Cab TRD
    5100's w/ Eibachs, Front sway bar in trash mod, Diff drop, 265/75-16 Duratracs or 33x10.50 KM2's on 15x8 wheelers steels, ARB front bumper, Warn VR8000 winch, Trailgear sliders, Allpro rear bumper, Sky Offroad E-Locker guard, Sky Offroad weld on differential guard, Savage skid plates w/ Budbuilt cross member, e-locker rear, ARB air locker front, 4.56 gears, bought it from my mom who bought it new :-D
    The inners are definitely the problem as you said. My truck still has the original outers and they look great but the inners are hurting. Did you consider doing the boot slide mod? People seem to be having good luck with that.
  7. Apr 27, 2012 at 1:31 PM
    Tacomadude89
    Austen
    Yup, I did the boot slide mod as well.
    Like you said though, I don't seem to understand why the market for them is for the lowers when the problem mainly occurs on the uppers. I've already called two different places who told me the only carry the lowers and that they do not know of any places that sell high angle inners. :confused:
    Anyway, after a bit more research I think I found what I'm looking for. Northwest Offroad has kit that supplies both upper and lower that are supposed to handle a higher angle better than stock from what they say due to the material. When I install them, I will do the boot slide mod to them as well. Looks like the kit also comes with grease so I can re-pack the cv's at the time of service.
    The kit is listed 3/4" of the way down the page,
    http://www.northwestoffroad.com/parts/servicesparts_drivetrain.php
  8. Apr 27, 2012 at 2:14 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Have you called and got prices on these?
  9. Apr 27, 2012 at 2:21 PM
    Tacomadude89
    Austen
    They're closed Fridays and Mondays so I'll have to try back on Tuesday.
  10. Apr 27, 2012 at 3:23 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I would like to know, keep me updated.
  11. Apr 27, 2012 at 3:31 PM
    Tacomadude89
    Austen
  12. Apr 27, 2012 at 6:41 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Sub'd. :popcorn:
  13. Apr 27, 2012 at 9:47 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
  14. Apr 28, 2012 at 2:40 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  15. Apr 28, 2012 at 3:51 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ^ I bought the 930 CV Bates, MRB-869306, but it was round inside, not the tri lobe needed for the top of the axle. I meant to return it but never got around to it. Which part number have you had success with?
  16. Apr 28, 2012 at 5:26 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I am curious to know which 930 boot is correct as well. Got a set of Advance Auto CV's on there now and would like to rebuild my factory ones.
    I don't know how Kartek's prices are but, in Porsche circles, Pelican is one of the best suppliers of parts.
    http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSaxl_pg1.htm
  17. Apr 28, 2012 at 9:54 AM
    Tacomadude89
    Austen
    +1.
    I was reading that some of the Tundra guys run these, but I couldn't identify whether or not they sold them for the Tacomas as well. I would assume both vehicles would have different part #'s. Some were reporting that they didn't have a tight fit.
  18. Apr 28, 2012 at 1:21 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Will the part # I run is for the tundra shafts. I'm running tundra cv axles cuz the burg LT kit. I'm sure someone could get the diameter of Tacoma and the tundra shafts, not sure on difference. Mine fit nice and snug no clamp necessary. If u want part # I'll find it.
  19. Apr 28, 2012 at 3:28 PM
    Tacomadude89
    Austen
    Thanks for the info Cory! I'll do a little more research on the 930 type and let you know if I have any other questions.
    Thanks again.
    I've noticed that in the description of a lot of these aftermarket boots, that it requires you to cut off the end of the original boot (the part the large clamp goes around), and then the new boot slides over the flange of the cut OE boot if that makes sense.
  20. Apr 28, 2012 at 5:45 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Yes that's what I did to get more GNARticulation, but for mid travel u would mount it there but leave old flange. I wouldn't think it cause an issue if ur not over articulating :notsure:
