Question regarding lift.
Discussion in 'Toytec Lifts' started by 10PreRunner, Aug 1, 2011.
  1. Aug 1, 2011 at 3:51 PM
    10PreRunner
    10PreRunner [OP] Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    I am wanting to lift my 2010 double cab, I'm only wanting 2.5 in. of lift. Would 5100s get me there for the front and the back? I have the TSB springs installed. Also, would i need UCAs to correct my alignment?
  2. Aug 1, 2011 at 5:02 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    From everything I have read, 5100's would get you there and you shouldn't need UCA's until going 3" and above...that being said, some have posted "wandering" at highway speeds when lifting Tacoma's without UCA's. I think it's kind of dependent on how you drive, what type of driving you do and even then I think results vary.
  3. Aug 1, 2011 at 5:09 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The above response is partially correct...
    Front Bilstein 5100's will lift you to 2.5". At 2.5" you're 50/50 on needing UCA's. Above 2.5" you should plan on needing new UCA's. The wander described above is caused by lifting and not being able to get your caster back within spec. Caster does not affect tire wear but can cause that wander feeling at speed. You'd need new UCA's to get your alignment back within spec.
    Rear 5100's do not provide any lift. With just the tsb pack, you'll be slightly nose high at 2.5" up front.
  4. Aug 1, 2011 at 5:41 PM
    10PreRunner
    Kevin
    Ok cool. Thanks for the help. I noticed toytec lists an aal as an option when you buy the 5100s. How would it sit then?
  5. Aug 1, 2011 at 6:20 PM
    Pugga
    Massachusetts
    From other's testimonials, the truck sits level when at 1.75 up front and the TSB rear. So if you're at 2.5 up front, a 1.5" aal in the rear would give you a slight rake. Again, that's just from reading other's results, I went a different route with my truck. :cool:
  6. Aug 1, 2011 at 8:49 PM
    10PreRunner
    Kevin
    What setup do you have Pugga?
