Question regarding OEM black running boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sixdoubleseven, Nov 16, 2009.
  1. Nov 16, 2009 at 4:14 PM
    sixdoubleseven
    sixdoubleseven [OP] Wrangler Convert
    Dave
    Boston
    2014 DC 4x4 Pyrite SR5
    Regarding the black oem running boards/steps. For the double cabs, is there only one model or is there one for the long bed and one for the short?
    It looks like there's only one size, but I'm not sure.
    Thanks
  2. Nov 16, 2009 at 5:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    They'll all be the same size - they don't go past the cab.
  3. Nov 16, 2009 at 5:55 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    -Just a heads up-
    I know my OEM Silver Toyota Steps from my long bed wont fit on a short bed.
    Here's a pic of mine when i had the side steps:
    ^^These are long enough so that you can step into bed if you needed to.
    Here's a pic of the OEM steps for a Double Cab Short Bed (Chopper4Pilot's truck)
    I dont know if the black ones you're talking about work the same way...but, i figured this would help out somewhat..
  4. Dec 7, 2009 at 7:30 AM
    sixdoubleseven
    Dave
    Boston
    I picked up the steps, but there was no hardware. Does anyone know what size bolts I should be using to mount them to the frame?
  5. Dec 7, 2009 at 3:51 PM
    Janster
    Jandy
    Lancaster, PA
    They don't bolt to the frame. They bolt to the body.
    The bolt to mount them is 8mmx1.25 pitch. I can't remember the overall length but It's pretty close to 1" or larger. I used flat & lock washers also
  6. Dec 7, 2009 at 8:46 PM
    sixdoubleseven
    Dave
    Boston
    Thank you very much for the info, Janster. Going to give them a go tomorrow morning.
    Did you use any thread lock or anything?
  7. Dec 10, 2009 at 1:58 PM
    sixdoubleseven
    Dave
    Boston
    Janster, how many bolts per side do you use?
  8. Dec 11, 2009 at 4:06 AM
    Janster
    Jandy
    Lancaster, PA
    There's a total of 6 mounting points. A total of 12 bolts.
    3 mounts/6 bolts per side.
  9. Dec 11, 2009 at 4:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Does mounting steps to the body like that not concern anybody else? How solid are they for normal size people?
  10. Dec 11, 2009 at 4:19 AM
    Janster
    Jandy
    Lancaster, PA
    Although they are mounted to the 'body' - it's not your typical body structure. The rocker panels are probably one of the strongest points (beside the frame) on the body. It's 'thick' where they mount. They feel pretty damn sturdy to me. The OEM running boards have a steal structure underneath the plastic covering.
    http://www.lieblweb.com/tacoma/Mechanical/RunningBoards/Step11.jpg
    I'm sure they have a 'weight limit', I'm just not sure what it is.
    Call any Toyota dealer and ask them what the weight limit is. They should be able to tell you.
  11. Dec 11, 2009 at 7:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hmm? OK, just struck me as odd when first seeing this & thinking it has to be bad somehow vs. bolting to frame.
  12. Dec 12, 2009 at 1:01 PM
    sixdoubleseven
    Dave
    Boston
    I installed the steps today. Went on so easy. I now realize what people complain about with the steps rubbing against pants. Once I get used to them I think it wont be a big deal.
  13. Apr 10, 2013 at 9:07 AM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    The same running boards I have they are very sturdy as I weigh 200+ pounds no problem. Function is not so good they sit pretty closse to the body. Looks are very good on my white truck.
  14. Apr 10, 2013 at 9:26 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    Holy thread resurection Batman.
