Question regarding re-using flywheel /balance shaft removed
Discussion in '4 Cylinder' started by D65C, Sep 6, 2023.
  1. Sep 6, 2023 at 10:54 AM
    D65C
    D65C [OP] New Member
    Derrick
    I recently purchased a brand new 2TR-FE long block with the balance shafts already removed. I have never worked on a 2TR before so please bear with me if my question seems a little armature-ish.
    So my question is: Now that the balance shafts aren't in the engine is there anything I need to do before and when installing my used flywheel? This engine does not seem to have any dowel or staggered bolt holes to insure proper installment of the flywheel.
    Any suggestions and/or help you can offer will be greatly appreciated.
    Thank you.
  2. Sep 6, 2023 at 11:12 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Wait for a Toyota guy to chime in but for general tips, Use locktite on the bolts or you're gonna have a bad time and walk over the flywheel with a roloc disk to clean it up
