Question regarding spidertrax spacers for first gen
Discussion in 'Wheels & Tires' started by Tacomadude89, Oct 11, 2010.
  1. Oct 11, 2010 at 12:15 AM
    Tacomadude89
    Tacomadude89 [OP] Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Hey guys,
    so I'm thinking about getting some Spidertrax wheel spacers for my '02.
    Anyway, obviously I need to order the lug centric ones because my truck a first gen, but I was curious as to why they also list the first gen Tacoma in the application guide for the hub centric ones? Mistake?http://www.spidertrax.com/Toyota-Hub-Centric-Spacer
  2. Nov 9, 2010 at 6:54 PM
    DblstuftTaco
    DblstuftTaco Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    Good question. I was wondering the same. Did you find any aswers?
  3. Nov 10, 2010 at 7:16 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Iirc, the hub centric ones are for trucks without manual locking hubs and the lug centric is for trucks with them.
  4. Nov 10, 2010 at 11:55 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Really doesn't matter which ones you use, unless you are using the Factory Toyota Alloy wheels. Then you need to use the Hubcentric spacers for the best fit.
  5. Nov 10, 2010 at 11:58 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I dont know how much spidertrax are, but I've had some trail gear 1.5'' spacers on for 50,000km with plenty of wheeling, and they are holding up perfectly fine!
    FYI
