Question regarding taco lean spacer
Discussion in 'Suspension' started by Jaredconat863, Jan 18, 2012.
  1. Jan 18, 2012 at 8:55 PM
    Jaredconat863
    Jaredconat863 [OP] Well-Known Member
    Jacksonville, Fl
    2008 pre runner 040
    Spindles , Bilstein 5100s set @ .85, eibach coils, rear 4 inch block. FJ steel wheels, 285/75/17 g2s
    I have rear tsb and 5100s @ 1.75 . My front is lower than the rear , still am considering going to 2.5 but for now I'm thinking about just fixing the taco lean on the drivers side . My question is where I can get one of these 1/4 top spacer and what are some opinions on adding the spacer. Thanks for any input
  2. Jan 18, 2012 at 9:09 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Plug in your TW data and get your discount....check vendor's forums.
    A real Taco lean "trim packer" sits on the spring seat with the OME system.
  3. Jan 18, 2012 at 11:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How long have you had the rear TSB??
    If you haven't had them very long - throw 200lbs in the bed and leave it there for a month. The rear will settle.....
    Then, after its settled...you can decide if you need to level it out or do anything with the front.
  4. Jan 18, 2012 at 11:27 PM
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    Are you just looking to get rid of the Tacoma lean or the Tacoma rake?
    I am not 100% sure but I think the top 1/4 spacers are for the Tacoma rake and the trim packer is for the Tacoma lean. Hopefully someone can confirm but Toytec does sell both.
    It says that it only works for the OME coils so maybe the spacer is what you are looking for.
  5. Jan 19, 2012 at 7:40 AM
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    Thanks for the input guys ! Yeah I've had the tsb for about a year now . Just looking to tighten up that driver side lean.
  6. Jan 19, 2012 at 8:28 AM
    Janster
    Jandy
    Lancaster, PA
    The trim packer is only for the OME (Old Man EMU) setup.
    The spacer is only 1/4" thick and will give you 1/2" of lift. That goes ontop of the coil assembly (inbetween the coil assembly and the mounting pocket).
    But wait.... You have 5100's in the front. Why don't you just crank the low side up a bit? No spacer needed...
  7. Jan 19, 2012 at 8:31 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Just a clarification , the OME trim packer , only for use with the OME shocks , goes at the bottom of the coil
    The 1/4" Toytec spacer , for use with 5100's , goes on top of the coil
  8. Jan 19, 2012 at 8:57 AM
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    I feel like setting the left side to 2.5 and leave the right at 1.75 wouldn't ride correctly . I don't know , maybe its mental . Also why does the 1/4 spacer net 1/2 inch of overall lift ?
  9. Jan 19, 2012 at 12:16 PM
    Janster
    Jandy
    Lancaster, PA
    You're right...it'll proload the spring. Whether its enough to 'feel' it....????
    The shock/strut is mounted on the lower a-arm, about 1/2 way between the pivot point and the end of the lower a-arm. Hard to explain....
    If the shock were mounted at the end of the a arm - you'd get the 1/4", but because its mounted in the middle - you get twice the throw for that 1/4" (approx - in leayman terms anyway)
  10. Jan 19, 2012 at 12:38 PM
    jflan
    Vancouver, WA
    I wouldn't monkey with dissimilar preload like that.
    I would use the 1/4" top plate spacer to correct the lean on the driver's side.
    BTW, what is the difference between the driver's front and the passenger front ?
    Good explanation Janster, on spacer/net lift relationship.
  11. Jan 19, 2012 at 12:42 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You have OEM coils and have the taco lean?
  12. Jan 19, 2012 at 12:45 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The lean is usually 3/8 to 1/2 inch. Even if you went dissimilar on 5100s the incriments are right at or right over 3/4 inch and would just cause it to lean the other way. I didn't have the lean on the 08 prerunner and didn't want to lift like on the 05 so I just used 2 lean spacers, 1 on each side to get 1/2 inch lift up front to level truck when swapping out the base tokicos with the oem TRD bilsteins.
    I had oem coils and lean on 05 prerunner AC and oem coils and no lean on the 08 prerunner RC.
  13. Jan 19, 2012 at 11:09 PM
    Janster
    Jandy
    Lancaster, PA
    I remember the first gen trucks - the OEM coils were side specific. Sometimes folks would get them swapped.
    Are the 2nd gen trucks side specific also?
  14. Jan 20, 2012 at 4:55 AM
    Pugga
    Massachusetts
    I could have sworn I read they were because people have put the coils on the wrong side and had some serious lean. That being said, I took my stocks off and I'll be damned if I can tell the difference between the 2 sides but I don't know how else to explain the need for a trim spacer on the driver's side when you go to an aftermarket coil. There isn't a spacer for the stock coils :notsure:
  15. Jan 20, 2012 at 6:59 AM
    Janster
    Jandy
    Lancaster, PA
    You gotta count the amount of windings in the coils. One of them will have an extra winding in it.
  16. Jan 20, 2012 at 7:02 AM
    Pugga
    Massachusetts
    I'll check tonight, I have the stock take-offs sitting in my garage but to the OP, did you put the coils back on the side they came off?
  17. Jan 20, 2012 at 7:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, they are side specific.
    The second gens dont have another wind, but rather the driver side is a tad longer.
  18. Jan 20, 2012 at 7:18 AM
    Pugga
    Massachusetts
    See, that's why you get paid the big bucks :thumbsup:
  19. Jan 20, 2012 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    unfortunatly, its monopoly money..:eek:
  20. Jan 20, 2012 at 7:52 AM
    Janster
    Jandy
    Lancaster, PA
    Depending on where you start counting the windings....it'll have an extra winding. :p:p:p:p
