Question: RPM drops at idol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lats, Sep 20, 2015.
  1. Sep 20, 2015 at 9:36 AM
    lats
    lats [OP] Member
    Alberta
    2006 DC TRD SPORT
    Hi All,
    I have a 2006 TRD Sport DCLB AT with 220,000 kms (137,500 miles) and all scheduled maintenance has been done. Recently my a/c light has started flashing and about the same time the truck has started having a sudden RPM drop when at idol (doesn't happen under throttle). It almost feels like the truck is about to stall, RPM's drop to about 400-500 and then will go back to normal.
    1) Could the RPM drop be due to the problem in the air conditioning?
    2) I was told I need a new a/c compressor. I won't need my air conditioning for about 6 months, would there be any harm in me just pulling the fuse or relay to deactivate the a/c system?
    3) Could this be a sign that I need the timing chain replaced?
  2. Sep 20, 2015 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'll second the above ^^^. Pull the fuse for the AC to prevent the clutch engaging until you get the AC repaired.
  3. Sep 20, 2015 at 8:01 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    I believe the defrost function runs the a/c to dry out the air, you may me a little foggy on your windshield in the winter without it, but if your a/c compressor is locked up it won't help anyway.
    regards to #3, your timing chain should still be fine
