Question(s) regarding cutting grill...
Discussion in 'HomerTaco' started by theTupper, Mar 8, 2012.
  1. Mar 8, 2012 at 6:41 PM
    theTupper
    theTupper [OP] White and Nerdy
    Jacob
    Raeford, NC
    '10 DCSB Off Road PreRunner
    1.) As I prepare to cut apart my grill I was just wondering if anyone (HomerTaco?) can offer some advice on how best to remove the triangles from the grill accurately. After inspecting the grill, it all seems pretty straightforward, but my Dremel obviously won't fit the angle needed to cut the triangles from the front. Could you tell me how you accurately remove the pieces for the triangle inserts? I have a tendency to overthink things like this and I'm currently envisioning drilling "marking" holes from the front to trace a template on the reverse and then Dremel it out, but surely there must be an easier way.
    2.) As I didn't wish to sacrifice my "working" (read: non-destroyed) grill on this experiment, I ordered a replacement on which to complete the work. It came in two pieces, as expected; the outer surround and the insert - to be connected by melting points. Thing is...I have no soldering gun/iron...any suggestions on alternate ways to attach the two pieces? The redneck in me says blow torch and knife, but I don't want to trash my work if I can avoid it!
    Any help you can offer would be gratefully accepted! TIA
  2. Mar 8, 2012 at 8:02 PM
    theTupper
    Jacob
    Raeford, NC
    bump for the night crowd :eek:
  3. Mar 9, 2012 at 12:57 PM
    theTupper
    Jacob
    Raeford, NC
    I thought there must have been someone else to figure this out...guess I may have the topic of my first write up...if I can figure it out myself! ha!
  4. Mar 12, 2012 at 5:19 PM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    This is the tool (and blade) I use for the triangles... Remember to always cut from the front side - trust me, you have less of a chance to eff it up that way...
    Tip: take a 3/16 Drill bit and drill holes in the corners first - this makes it much easier to just "connect the dots" with the Dremmel.
    It is also possible to cut them out with this:
    (but much harder to control)
    Tip: Do NOT run the Dremmel faster than 15K RPM's - you will do more melting than cutting. ;)
    If you do not have a soldering iron to connect the two piece aftermarket surround as illustrated in this thread.
    This is a suitable alternative:
    Hope that helps!
    ~ Craig
  5. Mar 12, 2012 at 5:39 PM
    theTupper
    Jacob
    Raeford, NC
    Thanks, dude. I can't see the picture of the first tool you posted as I get a blue question mark...could you check the link or just tell me the name of it?
    Also...do you happen to know the melting point of the plastic? How hot of an iron do I need...wattage etc? I can borrow one from a buddy. Thanks again for your input!
  6. Mar 12, 2012 at 5:49 PM
    HomerTaco
    Craig
    Bucks County Pa.
    It is a Dremmel Mullti-Max tool.
    IIR melting point of the ABS is 400*
    I can tell you the boiling point of ABS is 900* (don't ask):rolleyes:
  7. Mar 12, 2012 at 7:40 PM
    theTupper
    Jacob
    Raeford, NC
    Isn't the rule that when someone says, "don't ask," one always asks? :p ;)
