Question: Trailer Brake Controller
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TXTRDPro, May 16, 2020.
  1. May 16, 2020 at 3:03 PM
    2011TXTRDPro
    2011TXTRDPro [OP] Well-Known Member
    Bob
    2011TXTRDPro
    None
    Installed my Prodigy P2 brake controller and was wondering if I need to have the dealer program it, or is it good to go.
    Thanks in advance.
  2. May 16, 2020 at 3:35 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    If you installed it correctly it is good to go. Nothing for dealer to program regarding trailer brake controller addition.
  3. May 16, 2020 at 4:32 PM
    2011TXTRDPro
    Bob
    2011TXTRDPro
    None
    Thanks on my ford, I installed the factory controller in the dash but it had to be reprogrammed.
    EdinCincinnati likes this.
  4. May 16, 2020 at 11:00 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Fuckin fords
    :bananadance:
  5. May 17, 2020 at 3:22 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Read the instructions and adjust the knob for amount of braking - do in an area with some room.
    You want to set so trailer starts braking right before your Tacoma so you can feel a slight pull slowing you and that avoids the trailer trying to swap places (jackknife around) in heavy or emergency conditions.
    If new to towing the trailer brake controller can also be used alone to give it a tap if a big rig screams by you and the trailer starts wagging around. If you lift your foot off the gas when the rig passes it wags more as you are decelerating and hitch tongue weight changes. Torsion/weight distribution hitch helps all that too based on how heavy you tow. Light trailers do not need and most smaller single axle boats. Larger dual axles most do as weights go over 5000 lbs.
  6. May 17, 2020 at 6:53 AM
    2011TXTRDPro
    Bob
    2011TXTRDPro
    None
    muddog321
    Thanks for the tips!
  7. May 17, 2020 at 7:14 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Put the @ before the name and it will tag the person and show an alert to the tagged person and look like a hyperlink:
    @muddog321
