Question: Turbo vs Super Charger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josepenajr, Jan 14, 2014.
Question: Turbo STS vs Super Charger Tacoma?
Poll closed Feb 13, 2014.
  1. Turbo STS
    6 vote(s)
    12.5%
  2. Super Charger
    42 vote(s)
    87.5%
  1. Jan 14, 2014 at 4:49 AM
    josepenajr
    josepenajr [OP] Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    Question: Turbo vs Super Charger? what is better to add??
    Thanks
  2. Jan 14, 2014 at 5:20 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Depends on what you use the extra power for. For me, supercharger for the increase in low end torque for towing my travel trailer. Also for the taco it's been well developed by Toyota for a less fuss installation and longevity. A turbocharger has the potential for higher power output but usually they are sized on gas engines for higher rpm power gains. And for me there is no local support turbo tuning.
  3. Jan 14, 2014 at 5:31 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    This is already a pole in performance forum. Several pages of back and forth pros an cons there.
  4. Jan 14, 2014 at 5:33 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    It depends on what you are seeking. The turbo will give performance over a wider range of RPM with some increased MPG. The SC will give performance but not as much and not as much of an increase in MPG. You are more likely to blow the engine with the turbos because of the amount of power increase. With the turbos you also need to change the cam if you want them to work properly. Turbos are more expensive.
    Supercharger:
    PROS
    - relatively easy to install
    - instant throttle response (no spool time)
    - typically less expensive than turbos
    - Much less plumbing involved (air and oil)
    - Can be used with Common aftermarket exhaust systems and headers
    - Easier to tune
    - More reliable due to less to go wrong
    - More consistent power curve since it's directly linked to the engine.
    Cons:
    - Lack of tuning options
    - boost levels is fixed based on pulley size
    - Allegedly less efficient than turbos.
    - relatively linear power curve
    Turbos:
    PROS:
    - gives you a lot of options for both boost and tuning
    - boost can be adjusted on the fly
    - Supposedly more efficient at making boost than SC units
    - Has a steadily increasing power curve: the bigger the "bang" in the cylinder, the more it pushes the turbo and the faster the turbo spins resulting in that feeling of being "launched" after the turbos spool
    Cons:
    - LOTS of plumbing required.
    - Typically a lot of modification to the exhaust system on non-DIY kits
    - Significantly more expensive than most SC kits
    - More difficult to control if you're not used to it
    - Poor boost-throttle response without a specially designed cam
  5. Jan 14, 2014 at 5:45 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
  6. Jan 14, 2014 at 10:06 AM
    josepenajr
    Laredo , Texas
  7. Jan 14, 2014 at 10:06 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    True.
  8. Jan 15, 2014 at 5:13 AM
    josepenajr
    Laredo , Texas
    Looks like the Super Charger is the better choice
  9. Jan 15, 2014 at 8:55 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    This has Torspd written all over it.
  10. Jan 15, 2014 at 9:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    N/A. Stay N/A.
    Boost is an insatiable drug. Undeniable. SPG's go up while MPG's go down. More and more you want more. Just to feel the skinny pedal once more.
    The mods won't stop. The boost won't stop. Get boost and it infects your mind. It takes over your dreams... Get a cat. It will ignore you and you'll forget all about it. Ignorance is bliss. Dont do it!
    Or...... ... ... .. . Come over and I'll take your for a ride along.
  11. Jan 15, 2014 at 9:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh yeah. Don't buy an STS turbo kit. DO NOT. "I kill you".
  12. Jan 15, 2014 at 10:01 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Bahahahaha
  13. Jan 15, 2014 at 10:11 AM
    BradyT88
    BradyT88 Well-Known Member
    :rofl:
  14. Jan 16, 2014 at 4:34 PM
    josepenajr
    Laredo , Texas
    so what u recommend then?
  15. Jan 16, 2014 at 4:40 PM
    BradyT88
    The Supercharger is significantly easier and if you get the TRD S/C done through the dealership it won't void your warranty.
  16. Jan 16, 2014 at 5:05 PM
    Neb
    Neb Well-Known Member
    Ben
    Tennessee
    06 PreRunner TRD Sport
    TRD S/C, URD ShortShifter, URD Y-pipe, URD Mk2 Catback, URD 2.8Pulley, URD U-spec headers, Innovate AFR/Boost, AFE Intake
    Hahaha classic! And completely true..
  17. Jan 16, 2014 at 6:20 PM
    josepenajr
    Laredo , Texas
    okay thanks
  18. Jan 16, 2014 at 8:52 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Superchargers are what most people on TacomaWorld will recommend.
    You have two choices, the TRD Supercharger or the URD Supercharger.
    TRD is roots, which gives you an insane amount of power down low. URD is centrifugal, which is more like a belt driven turbo. Both are fun and neither will leave you disappointed.
  19. Jan 16, 2014 at 10:35 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Supercharger since both have been engineered specifically for your engine and both are easier to install.
  20. Jan 17, 2014 at 6:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the TRD was a twin screw design, and I didn't have a turbo, then I would be all over it. It isn't though.
    That being said, my next choice, behind turbo, would be a URD MKIII.
