QUESTION...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattB05SPORT, Feb 15, 2012.
  1. Feb 15, 2012 at 8:26 PM
    MattB05SPORT
    MattB05SPORT [OP] MATTBLEVINS
    GA
    05 PreRunner TRD Sport 4 Door
    STOCK BUT SOON TO BE MOD
    I have COOPER tires.. 265-70-17....I want to get some KMC ADDICTS 17x9...WIll they fit? they will be my first set of wheels so im new to this...Thanks!
  2. Feb 15, 2012 at 8:29 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
  3. Feb 15, 2012 at 8:29 PM
    98_Mud_bug
    lucedale Ms.
    what backspacing and offset?
  4. Feb 15, 2012 at 8:30 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    x2
  5. Feb 15, 2012 at 8:31 PM
    MattB05SPORT
    GA
    I dont know what backspacing and offset... Super new at this. I hardly know what that means haha. Sorry tryn to learn man
  6. Feb 15, 2012 at 8:45 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Research time:
    https://www.rsracing.com/tech-wheel.html
    http://www.tacomaworld.com/forum/wheels-tires/30754-wheel-specs.html
    One, make sure the hub bore on the wheel's is greater than the hub bore diameter on the tacoma which is 106mm. If you get a hub bore diameter smaller than 106mm, your wheels will not fit onto the truck.
    Two, backspacing is defined as distance from the surface of the wheel that mounts on the hub to the inner edge of the barrel of the wheel. the more backspacing the farther the wheel will be in the fender well. less backspacing will make it stick out more.
    Three: Get a bolt pattern 6X5.5, and you're gonna need new lug nuts since aftermarket wheels are lug centric, and stock wheels are hub centric, so your stock lug nuts won't work. You'll need a conical set with a thread pattern of 12 x 1.5
    Offset and backspacing are up to you honestly. These determine the FITMENT and look of the wheel on your truck. You go with a huge backspace, you'll be hella tuck, but might rub on the UCA, go with a small backspace, you'll be hella flush, but you'll contact the fender when flexing. Most guys around here run a 4.5 backspace which is about the same as stock. Offset is your choice really; Neg offset, get a nice bowl, concavity in your wheel. Pos offset, kinda convex, bowed out. Zero offset, flush.
    A couple definitions for you:
    Bolt pattern or lug pattern or bolt circle is determined by the number of bolt holes and the bolt circle diameter.
    Hub Diameter or center bore is the hole at the center of the wheel.
    Rear spacing or back spacing is the distance from the backside of the wheel mounting pad to the outside of the rim flange.
    Offset: The distance from the centerline of the wheel to the mounting surface of the wheel.
    Negative offset: When the back of the bolt pad is closer to the inside of the wheel; when mounting surface is inboard of the rim centerline.
    Positive offset: When the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline.
    Offset
    Lea esta página en español
    The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
    Zero Offset
    The hub mounting surface is even with the centerline of the wheel.
    Positive
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
    Negative
    The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
    If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
    *Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
    Bead-Loc A device which captures the tire bead between it's flanges, usually secured by bolts to keep tire bead from dismounting. Usually used in dirt circle track or off road applications where low tire pressures are used and hitting ruts or other vehicles are common. Left: An example of a Bead-Loc wheel
  7. Feb 16, 2012 at 3:15 PM
    MattB05SPORT
    GA
    :DThat really helped....appreciate the help alot
