Question?
Discussion in 'Suspension' started by IC MANDO, Mar 24, 2013.
  1. Mar 24, 2013 at 5:57 AM
    IC MANDO
    IC MANDO [OP] Well-Known Member
    Isaac
    Fort Irwin CA
    '11 TDR SPORT
    3" ProComp coilovers , Radar Renegades R7 M/T-295/70R17 , ProComp rims, N-Fab step bars, CB Radio, ICOM Race Radio roof cage and 32" light bar, LED MOD (Green) interior lights, Debadged, Lime Green Devil Horns Emblem, Tiregate, Roto Pax, rear led light bar, custom rear bumper
    I have a 3" Rough Country spacer. If I get some Billy's adjustables, is that considered staking lifts? Can I set the Billy's at .75 or do they have to be at 0?
  2. Mar 24, 2013 at 6:34 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    .. most guys on here don't like spacer lifts anyway...but I would say no to just play it safe.. if you did I would think you would need LCA and UCL...to compensate for the travel of the suspension..do you have the front diff drop and extended brake lines?... if not I would recommend them
  3. Mar 24, 2013 at 6:41 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You can put your 3" spacer on the 5100's if they're set at 0 (although I would not recommend it). 5100's set at 0 are no different than a stock shock as far as function so putting a top spacer lift on them is no different than putting a spacer on top of a stock shock. The whole point of the 5100s though is so you don't have to use top plate spacers but rather get lift from setting the lower coil seat up and preloading the coil to get lift. I would not put a top plate spacer lift on 5100's if you plan on putting the 5100's at any other setting besides 0. That would be considered stacking lifts.
    If I were you, I'd scrap the spacer lift and go with 5100's set at 1.75 or 2.5 to get your lift (or get lift coils like OME 885 or Eibach coils).
    Your post has a lot of misinformation in it... There's no reason to change LCA's with that type of lift, no idea what a UCL is, extended front brake lines are not required and a differential drop on a 2nd Gen is useless.
  4. Mar 24, 2013 at 6:43 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    Manitoba
    08 TRD
    You shouldn't attempt mix a spacer lift with a preloaded 5100. It is not recommended because it is dangerous.
    Edit: Shoulda know Pugga would beat my post...llol
  5. Mar 24, 2013 at 6:46 AM
    Jeffvt0508
    Jeff
    Columbia, SC
    honestly I didn't even know I posted anything in here.. sleep posting?.. I have no clue what I was even sayin.. wow thats scary sorry OP for that
  6. Mar 24, 2013 at 6:49 AM
    Pugga
    Massachusetts
    F-150 Mod
    :eek:
    It happens. Look at Mr. Chris16's drunking/sleeping posts :laugh:
  7. Mar 24, 2013 at 8:32 AM
    IC MANDO
    Isaac
    Fort Irwin CA
    '11 TDR SPORT
    So I can scrap the spacer. Are ProComp lift springs good. I won a 4wheel Parts gift card for $500.
  8. Mar 24, 2013 at 10:25 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    If you really are set on the pro comp then just run the pro comp lift cause they come with front and rear shocks so no need for 5100's.
  9. Mar 24, 2013 at 4:43 PM
    Pugga
    Massachusetts
    F-150 Mod
    If it's the springs I'm thinking of, they are very, very stiff coils. They'll work for your lift but the front end will ride rough. If you use their coils, you're better off using their shocks also as mentioned above. Does 4wd sell Old Man Emu stuff?
  10. Mar 25, 2013 at 2:16 AM
    IC MANDO
    Isaac
    Fort Irwin CA
    '11 TDR SPORT
    They have OME aals and fronts shocks. That's it.
  11. Mar 25, 2013 at 2:12 PM
    IC MANDO
    Isaac
    Fort Irwin CA
    '11 TDR SPORT
    I think I'm gonna go with the Pro Comp coils and the Pro Comp ES 6000 shocks. Any suggestions?
  12. Mar 26, 2013 at 5:09 PM
    IC MANDO
    Isaac
    Fort Irwin CA
    '11 TDR SPORT
    Thanks for the help
  13. Mar 26, 2013 at 5:44 PM
    Pugga
    Massachusetts
    F-150 Mod
    Sorry, I guess no one checked back in your thread. It'll be a stiffer ride but it's not an uncommon lift.
