question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrandonTorgerson, Jun 3, 2010.
  1. Jun 3, 2010 at 6:59 PM
    BrandonTorgerson
    BrandonTorgerson [OP] Well-Known Member
    Brandon
    Signal Hill, Ca
    09 Tacoma TRD Sport 4X4
    Camburg 3'' lift 2.5 coilover race runner shocks, uni-ball upper arms by camburg, AllPro 11 leaf pack with fox 2.0 performance shocks, TRD Cold air intake, TRD Cat Back System, 285/70/R17 BFG MT KM2s On Balistic Inigmas
    one quick question... i went ahead today and made a cai cover from 1/4 inch plexiglass and when i screwed it in i noted not to screw them in to tight to avoid cracking it, so i used tread locker. drove it around and then checked it out, it starting to splenter and crack around the holes where i drilled threw the plexiglass, they where not there before i drove around... so i going to make a new one... so back to my question, what do you use to avoid cracking it? i also used stick on 1/4 inch foam for an air tight seal... is this necessary?
  2. Jun 3, 2010 at 8:43 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Why plexiglass? It's going to crack with all the vibration.
  3. Jun 3, 2010 at 8:44 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    well i like the way you can see threw it !
  4. Jun 3, 2010 at 8:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Good for you, but it's still going to crack. And it's through, not threw. Threw is the past tense of throw.
  5. Jun 3, 2010 at 8:52 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Exactly, that is why companies make the shield out of aluminum or metal.
  6. Jun 3, 2010 at 8:52 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    It did crack because i did not put any rubber washers in. Went and bought some so now ill give it another try.
  7. Jun 3, 2010 at 9:02 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    yeah, thats a thought. a lot of people have done this, so i gave it a shot. Besides it does look a hell of a lot better clear then with the aluminum in my point of view.
  8. Jun 3, 2010 at 9:09 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Also you need to reduce the stress by counter sinking the holes. You don't want any rough edges cause microscopically they are 'cracks' and then you have the engine vibration and the crack propagates. This is why they polish the insides of race and aircraft engines, connecting rods, etc, to reduce small cracks to larger cracks and then, you know BIG CRACKS!!!
  9. Jun 3, 2010 at 9:11 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    will do that as well, was talking to my dad about it earlier, and he said the same thing!
  10. Jun 3, 2010 at 9:18 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    heres a pic
  11. Jun 3, 2010 at 9:22 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    ok ill do that tomorrow, and we will see what happens. this was just the first attempt. hahah
  12. Jun 3, 2010 at 9:29 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    you can always pick up a sheet of clear LEXAN from a hobby shop and cut to fit. Lexan is tough and takes a beating.
  13. Jun 3, 2010 at 9:32 PM
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    thats what i started with, but when i went to drill it, it cracked.. so i switched to 1/4 inch plexi and it held up for a bit. i did not install it right so it cracked>>>
