Questionable cali emissions?!?!?1
Discussion in '1st Gen. Tacomas (1995-2004)' started by rebethunder333, Jan 21, 2010.
  1. Jan 21, 2010 at 7:49 PM
    rebethunder333
    rebethunder333 [OP] New Member
    Jon
    Virginia / North Carolina
    00 4cyl 4wd Taco
    I have a 2000 tacoma 4wd with a 2.7L. Truck has california emissions on it, but resides on the east coast so legality isn't an issue. Used to get 20- 24 mpg all day long, then suddenly dropped to 15 mpg on a good day. Check engine light has been on since I bought the truck in '03 but only for a "catalyst" code. since the fuel milage dropped i have gutted the catalytic converter ( both of them, thanks california!!) and gained a little power back, but absolutely no fuel economy. air/fuel delivery/gears/tires all stock. Any help would be awesome, oil changed regularly plugs, and air filter within the past year. this is pissing me off because i love this truck and the gas milage is horrible!!!
  2. Jan 22, 2010 at 3:41 AM
    Brunes
    Brunes abides.
    Rotorhead
    Well...If you USED to get 20-24 and then it dropped outta no where- My guess is that "catalyst" code is actaully a valid code and until you get it fixed or get a signal bypass you are in "limp" mode in the ECU.
    It won't let the engine perform to max available and that means you are pushing the skinny pedal WAY more to do the same things.
    Get the code checked again....Make sure nothing new has popped up and then get your truck fixed.
  3. Jan 22, 2010 at 4:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    x2
    Sounds like a bad AFR sensor
  4. Jan 22, 2010 at 6:03 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    What code were you getting? Just because a code is associated with catalytic converter operation doesn't mean the cat is the only possible cause.
