Questionable Jack point at Discount Tire
Discussion in '4th Gen. Tacomas (2024+)' started by TacoRancher, Nov 12, 2024.
  1. Nov 12, 2024 at 2:39 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Guys, Discount Tires jacked up my truck at the rear control arm bracket. When I saw them doing this I got sick to my stomach. Is that acceptable? The metal doesn’t look thick enough to support that kind of weight. The manual certainly doesn’t list that as a jack point.
    I think it’s probably fine but I cannot tell if it’s ever so slightly bent? I don’t know. Is this normal? The guys said they do it every day. Seems dumb to me and really lazy. Any thoughts would be really appreciated. If you need more pictures please advise. Tagging @Discount Tire
  2. Nov 12, 2024 at 2:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m gonna say it’s probably ok but if the truck must be parted out, I would appreciate first dibs on the dash and seats. Thanks!
    AZgolfGuy, Bitflogger, 23MGM and 4 others like this.
  3. Nov 12, 2024 at 2:52 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    its fine....
  4. Nov 12, 2024 at 2:57 PM
    TacoRancher
    Houston
    I can also sell you the scrap metal after it's all parted and sold. If I were you I would just melt it down.
    Steves104x4[QUOTED] likes this.
  5. Nov 12, 2024 at 2:58 PM
    TacoRancher
    Houston
    I think you're right, but man... that metal doesn't look thick enough.. but I guess it is. I will never let anyone do that again.
    PDKTaco likes this.
  6. Nov 12, 2024 at 8:29 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
  7. Nov 12, 2024 at 8:40 PM
    TacoRancher
    Houston
  8. Nov 12, 2024 at 8:40 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    You would have bent it on a rock anyways. Yolo
    PDKTaco and TacoRancher[OP] like this.
  9. Nov 12, 2024 at 9:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally, No. You wouldn't "want to" use that as a jack location.
    You also would not want the customer to see you do it, if you did it.
    Which is why a lot of shops, don't have widows to the service area.
    And if they do, they cover them with signs.
    I can see both sides.
    To me, I'm not too worried about it.
    The rear of the truck isn't that heavy. It has less that 25% of the total weight on it.
    And the lift isn't slamming into it.
    It's fine.
    Not ideal. But fine.
    Steves104x4 and TacoRancher[OP] like this.
  10. Nov 12, 2024 at 9:42 PM
    TacoRancher
    Houston
    I agree. It just gets tiring when nobody wants to do anything correctly anymore. It’s just faster cheaper dumber forevermore.
    Steves104x4 likes this.
  11. Nov 12, 2024 at 10:20 PM
    MGMDesertTaco
    I had a discount tire jockey lift a 4th gen f body with a jack directly under the front fenders. Those are unibody cars btw. Completely fubared the car. Over 4k in paint and bodywork later. :rolleyes:
    I've lifted my 3rd gen with a jack under the leaf spring bolts in a pinch when rotating tires without jack stands. A floor jack on the frame by the front door and a floor jack in the rear under the leaf spring bolts. One side at a time, so the e brake can at least hold one rear wheel. :anonymous:
    Only need an inch or so of clearance to remove and rotate. :humble::crazy:
  12. Nov 12, 2024 at 10:27 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    I liked it when @Discount Tire monitored TW and would chime in. Since it's your truck, it's probably fine... But seriously, I get it, that would bug me too. That metal does kind of look like I could bend it with needle nose pliers. It'll probably rust off first anyway.
  13. Nov 12, 2024 at 10:32 PM
    MGMDesertTaco
    Rust off first, yep. OP's got white paint too. That'll probably start flaking off soon. Another thing to worry/obsess over. :p
    fatfurious2 and 23MGM like this.
  14. Nov 13, 2024 at 4:51 AM
    TacoRancher
    Houston
    all of it has flaked off in the two months I’ve owned it, but the primer looks awesome on the Trailhunter
  15. Nov 13, 2024 at 4:54 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Phlogiston likes this.
