questioning lifting truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marty Mcfly, Dec 16, 2010.
  1. Dec 16, 2010 at 12:13 PM
    Marty Mcfly
    Marty Mcfly [OP] Well-Known Member
    Jud
    Bay Area California
    2010 SR5 "Super White" 4x4 V6 6speed manual
    hey there,
    have a quad super white 2010 4x4 6 speed. wanting a small lift. dont do hardcore offroading and the taco is my DD. Whats a good lift size? like a 1.5? 1.75? also wondering if i should just do spacers...
    pros? cons? suggestions?
    Thanks!
  2. Dec 16, 2010 at 12:14 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    bilstein 5100s. front to 1.75".
  3. Dec 16, 2010 at 12:18 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    Don't do spacers unless you don't mind compromising your ride substantially.
    Billstein 5100's are the way to go.
  4. Dec 16, 2010 at 12:19 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i vote 5100's at 2.5". 1.75" seems hardly noticeable IMO, but whatever you go with, don't get spacers! OME is also a great option.
  5. Dec 16, 2010 at 12:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I say if your gonna lift, might as well go 3"s! Check out toyteclifts.com
  6. Dec 16, 2010 at 12:28 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    but then he'd have to spend another $600 on uca's.
  7. Dec 16, 2010 at 12:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nah, I disagree.
    3" doesn't seem like much, but it's pushing our little trucks pretty hard.
    20% of folks lifting 3" experience VSC issues.
    3" needs UCAs.
    3" makes the ride stiffer/harsher.
    3" much more likely to get driveline vibes.
    OP: I think your 1.75" with 5100s is probably a good choice. Personally, I don't like "levelled" and think a truck needs a little rake for carrying cargo, so I'd put a 1.5" AAL in the back to match up with the 5100s.
    265/75R16 is a good tire size to run with that. Most folks won't think you've modified your truck, they'll just think "it looks really good."
  8. Dec 16, 2010 at 1:03 PM
    Marty Mcfly
    Jud
    Bay Area California
    Ok so 1.75 sounds good then. A little unclear on how it goes. a 1.75 in front and a 1.5 in the back?
    Thanks alot for the input guys. I definately dont want to lose too much of the ride so i wont just do spacers.
  9. Dec 16, 2010 at 1:11 PM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    Anybody running this set-up post pics? (or links to pics?)
    TIA
  10. Dec 16, 2010 at 1:55 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Sometime in the last month someone created a thread asking for that. If you look for it you can probably turn it up.
  11. Dec 16, 2010 at 2:12 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's all plus or minus about half an inch anyway. We're measuring springs with weight on them here. ;) And out of the box, the truck typically has about 2" of rake. So within the tolerance of the measurement, you're lifting the front and back roughly the same amount here.
  12. Dec 16, 2010 at 2:15 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    1.75" up front and the rear spring tsb in the back.
  13. Dec 16, 2010 at 2:18 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    NICE! i take back what i said before about 1.75" not being noticeable, that truck looks good!
  14. Dec 16, 2010 at 2:21 PM
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    ok.. now im back to my original idea of getting the adjustable 5100s instead of the 3" lift due to money.. ha .. so i can set the front at 1.75 and that will almost be almost level right? (i dont want the rake) but if i set them at 1.75 will i need uca or anything? i thought i read somewhere you couldnt run it that high? i just dont want it to add stress to anything or break anything.. and i still want to be able to run something over..
  15. Dec 16, 2010 at 2:22 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    1.75 up front 1.5" aal in rear ( non tsb ) i can get a better picture tomorow if you'd like
    this is with stock tires 265/65/17
    Im pretty sure im the one hes referring to that asked this last month too
  16. Dec 16, 2010 at 2:24 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    Im at 1.75 up front with no alignment issues, so no need for UCA's with this set up for me at least every truck is a little different
  17. Dec 16, 2010 at 2:26 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Thanks man! I think its a great look.
    Here is the same set up with different tires. Didn't have any other side shots on flat ground with these tires.
  18. Dec 16, 2010 at 2:30 PM
    Xshark
    Michael
    Rogers, AR
    08 Taco
  19. Dec 16, 2010 at 2:47 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    thanks. if the dealership had my truck in green i would have bought it but they didn't so i ended up with the grey.
    i dont see any 4x4 green double cabs out here but i sure see a lot of greys.
