Questions about 02 & Air/fuel sensors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sittingbull2, May 13, 2013.
  1. May 13, 2013 at 2:12 PM
    Sittingbull2
    Sittingbull2 [OP] Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Attached or some pics of my new sensors and old sensors. New ones are from Rockauto. I pulled my front sensor out I suppose it is considered a Air/fuel sensor. But the old Air sensor does not look like the new air sensor. It looks like a 02 sensor. Plus the new Air/Fuel Sensor connector is not the same but the new 02 sensor connector is the same. Truck is a 2000 model could it possible they didn't change from front 02 sensor to Air/Fuel sensor at sometime it was a left over where they have (2) 02 sensors front of the cat and the one behind the cat? Anybody I could use some help here. Thanks
  2. May 13, 2013 at 2:26 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    the old one doesn't look like the new one because it is OLD. If the plugs are the same, you should be good.
  3. May 13, 2013 at 5:33 PM
    Sittingbull2
    Mitch
    Southeast texas
    Yeah i know its old. But would it matter the old having so many more holes in it versus the air/fuel sensor having fewer holes. Plus why would it be called a air/fuel sensor versus 02 sensor. Is there a difference in the them besides the holes in the sensors?
  4. May 13, 2013 at 5:45 PM
    JudoJohn
    St. Louis
    they are the same thing. the O2 sensor reads the amount of gases and helps your ECU send the signal to the fuel injectors for the proper amount.
  5. May 13, 2013 at 5:50 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    How much did it cost if you dont mind asking, i have to replace mine in my 99 and havnt got around to check what they run....
  6. May 13, 2013 at 6:00 PM
    Sittingbull2
    Mitch
    Southeast texas
    Denso Downstream was $54.79
    Denso Upstream was $116.79 I think I need to send back the upstream one because mine is just a regular 02 sensor I guess. instead of a Air/Fuel Sensor plus it will save me about $60 dollars.
  7. May 13, 2013 at 6:05 PM
    Sittingbull2
    Mitch
    Southeast texas
    Look in my picture they are different Air/Fuel Sensor has 8 holes spaced apart around the sensor and one on the end. And the 02 sensor has 18 holes spaced apart around the sensor and none on the end.
  8. May 13, 2013 at 6:08 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    :thumbsup: Thanks!
  9. May 14, 2013 at 12:49 PM
    Sittingbull2
    Mitch
    Southeast texas
    Well finally got it figured out about the A/F sensor. My truck is a non California model meaning it is a Federal emission type even though it was made in California according to my VIN. Doesn't mean it has Calli. Emissions. It also is a lot cheaper for the Non Calli. A/F sensor by about $60. Information somebody else may use in the future. Check under your hood and see if it is Calli. emission or federal emission should have a tag on your hood. Mine didn't. People at Rock Auto or excellent on customer service. They took the time to figure it out. And A/F sensors are different they monitor your fuel better than just a plain old 02 sensor. Kuddos to BamaToy for his help.
