Questions about aux fuse panel install
Discussion in 'Technical Chat' started by Tim A, Apr 12, 2010.
  1. Apr 12, 2010 at 2:15 PM
    Tim A
    Tim A [OP] Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I'm going to be adding some lights, CB, OBA, etc. to the truck so instead of running everything to the battery I want to install Blue Sea (or similar) aux fuse panel under the hood.
    I know a few people have done this so I have a question or two:
    - On the Blue Sea panel, there's a ground bus. That must mean I need to ground the fuse panel correct? I plan on using 1 ga from the battery for power...will 1 ga work for the ground too?
    - Some have used a breaker between the aux panel and the battery. Others have gone with a fuse. What are the disadvantages, if any, of a breaker?
    - When choosing the size of breaker or fuse between the battery and fuse panel, do you just total up the current of all your accessories running off the panel?
    Thanks:thumbsup:
    Tim
  2. Apr 12, 2010 at 4:23 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    1. Yes
    2. Breaker is resetable, fuse must be replaced. Breakers are also tricky as they do allow for overcurrent to a point (under certain time limits) so you need to spec on that will pop before it does damage to your stuff. I chose a large fuse (though fuses are not perfect either).
    3. No, the aux block should have a max allowoable. For the blue sea I used it is 100A. This means that I can either run 10 10A things or 1 100A thing and the rest of the terminals are blank. So nomatter you are limited to 100A, as that is all the aux lock can handle. This is what you would chose for your breaker/fuse...100A (or whatever the overall limit of your block is)
    Details on my install are in my build thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html
  3. Apr 12, 2010 at 6:11 PM
    Tim A
    Montana
    Thanks Robert
  4. Apr 12, 2010 at 6:13 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    1 ga would be overkill.
